* | Added shell of information on resources for embedded information. | Joel Sherrill | 1999-07-15 | 3 | -1/+44 |
* | Corrections from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1999-07-15 | 1 | -4/+4 |
* | Added information on hardware to aid in debugging. Primarily this is | Joel Sherrill | 1999-07-15 | 5 | -4/+95 |
| | | | | information on gdb and bdm for the MPC8xx, MC683xx, and ColdFire. | ||||
* | New file. | Joel Sherrill | 1999-07-14 | 1 | -0/+19 |
* | Added comment on where this manager came from. | Joel Sherrill | 1999-07-13 | 1 | -1/+2 |
* | Update from Jeff Mayes, Jennifer Averett, and Suzie Provitt. | Joel Sherrill | 1999-07-13 | 1 | -17/+160 |
* | Update including fixes for my comments from Xiangyang Wu <wux@cspar.uah.edu> | Joel Sherrill | 1999-07-13 | 1 | -734/+858 |
| | | | | and xing@ebs330.eb.uah.edu. | ||||
* | Added section on Free Software that Supports RTEMS. | Joel Sherrill | 1999-07-13 | 3 | -1/+79 |
* | changed version to 19990709 | Joel Sherrill | 1999-07-09 | 1 | -1/+1 |
* | Updated version | Joel Sherrill | 1999-07-09 | 3 | -11/+11 |
* | Added information on the workspace versus heap. | Joel Sherrill | 1999-07-09 | 1 | -0/+5 |
* | Some cleanup to make it format better. Compensated for multiple services | Joel Sherrill | 1999-07-08 | 1 | -31/+142 |
| | | | | on a single page. | ||||
* | First draft from Xiangyang Wu <wux@cspar.uah.edu>. | Joel Sherrill | 1999-07-08 | 1 | -12/+351 |
* | From Fei Ling <fling@cs.uah.edu>. | Joel Sherrill | 1999-07-06 | 1 | -19/+524 |
* | Added a lot of information on confdefs.t | Joel Sherrill | 1999-07-03 | 1 | -16/+367 |
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 2 | -4/+68 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 27 | -35/+10 |
* | Changed System Database routines to implemented. | Joel Sherrill | 1999-07-03 | 1 | -10/+10 |
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 |
* | Corrected formatting so argument was in code font. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 |
* | Filled in. | Joel Sherrill | 1999-07-01 | 1 | -10/+30 |
* | Cleaned up and much neater. | Joel Sherrill | 1999-07-01 | 1 | -19/+33 |
* | Corrected and fleshed out. | Joel Sherrill | 1999-06-18 | 1 | -43/+2 |
* | Directives -> services. | Joel Sherrill | 1999-06-15 | 1 | -4/+4 |
* | Some stuff added. | Joel Sherrill | 1999-06-15 | 1 | -38/+131 |
* | Significantly enhanced. At least the per routine pages for this chapter | Joel Sherrill | 1999-06-15 | 1 | -59/+349 |
| | | | | are now filled in. | ||||
* | Added information on pathname evaluation. | Joel Sherrill | 1999-06-11 | 1 | -1/+14 |
* | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 1999-06-04 | 13 | -249/+361 |
| | | | | class. | ||||
* | Added much of the text required to turn this into a real chapter. | Joel Sherrill | 1999-06-04 | 1 | -52/+195 |
* | New file. | Joel Sherrill | 1999-05-26 | 1 | -0/+4 |
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 13 | -253/+257 |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 11 | -83/+166 |
| | | | | The style in the output is not right but it is a good starting point. | ||||
* | Basic prototypes are now included. | Joel Sherrill | 1999-05-26 | 1 | -1/+6 |
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 12 | -180/+184 |
| | | | | the descriptive titles. | ||||
* | Changed word "directive" to "system call." | Joel Sherrill | 1999-05-26 | 1 | -1/+1 |
* | Added error codes to all service calls | Joel Sherrill | 1999-05-26 | 1 | -14/+190 |
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 12 | -168/+0 |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 12 | -252/+84 |
* | Enhanced. | Joel Sherrill | 1999-05-26 | 1 | -63/+156 |
* | Initial revision | Joel Sherrill | 1999-05-20 | 16 | -0/+4561 |
* | Fixed typo. | Joel Sherrill | 1999-05-14 | 1 | -1/+1 |
* | Added tool hints. | Joel Sherrill | 1999-05-14 | 3 | -1/+12 |
* | New file. | Joel Sherrill | 1999-05-14 | 1 | -0/+47 |
* | Fixed Makefile to avoid copying the file to a new name. | Joel Sherrill | 1999-04-23 | 1 | -1/+0 |
* | Changed date. | Joel Sherrill | 1999-04-23 | 7 | -28/+27 |
* | Switched to full doc set. | Joel Sherrill | 1999-04-23 | 1 | -1/+30 |
* | Updated to reflect inclusion of IRQ test in ada examples. | Joel Sherrill | 1999-04-20 | 1 | -3/+7 |
* | Added FAQ to the documentation set. | Joel Sherrill | 1999-04-19 | 3 | -12/+9 |
* | Added debugging hints to the FAQ. | Joel Sherrill | 1999-04-19 | 3 | -8/+10 |
