* texi2www: Add provisory support for @image.
* user/rtemsarc.gif, user/states.gif, user/rtemspie.gif:
Remove (Unused).
* user/rtemsarc.txt, user/rtemspie.txt, user/states.txt:
New (Extracted from other docs).
* user/Makefile.am: Reflect changes above.
* base.t: Remove.
* Makefile.am: Remove base.t.
* index.html.in: Remove OR32.
* eventlog.t: Remove.
* new_chapters.texi: Remove eventlog.
* Makefile.am: Remove eventlog.
* dumpcontrol.t: Remove.
* new_chapters.texi: Remove dumpcontrol.
* Makefile.am: Remove dumpcontrol.
* confspace.t: Remove.
* new_chapters.texi: Remove confspace.
* Makefile.am: Remove confspace.
* adminiface.t: Remove.
* new_chapters.texi: Remove adminiface.
* Makefile.am: Remove adminiface.
* user/io.t: Change rtems_io_register_name to take a const char *.
PR 365/rtems
* supplements/arm/cpumodel.t: Removed unused ARM_HAS_CLZ macro
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi,
FAQ/concepts.texi, FAQ/debug.texi, FAQ/endoftime.texi,
FAQ/freesw.texi, FAQ/hwdebugaids.texi, FAQ/projects.texi,
FAQ/tools.texi: Remove (Generated files).
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
* user/region.t: Add documentation on region_resize_segment.
* bsp_howto/rtc.t: Rewritten to account for removal of dmv177.
* networking/decdriver.t: Make PCI initialize function part of the
unified PCI API as pci_initialize().
PR 706/doc
* user/task.t: Remove not that changes explanation.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* intro.texi, status.texi: i960 obsoleted.
* supplements/Makefile.am: i960 obsoleted.
* supplements/i960/.cvsignore, supplements/i960/CVME961_TIMES,
supplements/i960/ChangeLog, supplements/i960/Makefile.am,
supplements/i960/bsp.t, supplements/i960/callconv.t,
supplements/i960/cpumodel.t, supplements/i960/cputable.t,
supplements/i960/fatalerr.t, supplements/i960/i960.texi,
supplements/i960/intr_NOTIMES.t, supplements/i960/memmodel.t,
supplements/i960/preface.texi, supplements/i960/timeCVME961.t: Removed.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
* FAQ/build45.t: Misc. corrections.
* rgdb_specs/layers.txt, rgdb_specs/process.txt,
rgdb_specs/seqbreak.txt, rgdb_specs/seqdetach.txt,
rgdb_specs/seqinit.txt: New.
* rgdb_specs/comm.t, rgdb_specs/conclusion.t,
rgdb_specs/gdbinternals.t: Use @image for
ASCII figures (Reflect changes above).
* common/rtems.texi.in, FAQ/basic.t: Remove RTEMSSNAPSHOTS,
RTEMSSNAPSHOTSSUBSCRIBE.
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/tools.texi,
FAQ/version.texi, FAQ/stamp-vti: New.
FAQ/version.texi: New.
* networking/networkflow.txt, networking/PCIreg.txt,
networking/recvbd.txt: New.
* networking/decdriver.t, networking/networktasks.t: Use @image for
PR rtems/652
* user/signal.t: Return RTEMS_INVALID_NUMBER when sending an empty
signal set.
PR 631/rtems
* user/msg.t: Document the return status from message_queue_create when
unable to allocate message buffer memory.
PR 627/doc
* user/task.t: Behavior documented for an rtems_task_create with
stacksize < minimum was not the implemented behavior.
