2000-04-26 | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 135 | -13751/+18326 | |
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | |||||
2000-04-25 | Merged changes from 4.5 branch and removed that branch. | Joel Sherrill | 11 | -49/+154 | |
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+2 | |
adds .cvsignore. | |||||
2000-03-24 | Added instructions on running ttcp from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1 | -0/+37 | |
2000-02-29 | Eric Norum spotted this sentence where it said preemption had to be | Joel Sherrill | 1 | -1/+3 | |
disabled for timeslicing to happen. This was wrong. | |||||
2000-02-23 | Changed to 4.5.0-beta1b. | Joel Sherrill | 2 | -6/+6 | |
2000-02-23 | Added a comment. | Joel Sherrill | 1 | -0/+4 | |
2000-02-23 | New file. | Joel Sherrill | 1 | -0/+368 | |
2000-02-22 | Adding information on prebuilt toolset binaries. | Joel Sherrill | 6 | -34/+72 | |
2000-02-22 | New file. | Joel Sherrill | 1 | -0/+48 | |
2000-02-18 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
2000-02-18 | Patch from Eric Norum <eric@cls.usask.ca> to include some information | Joel Sherrill | 1 | -0/+8 | |
on simple binary semaphores. | |||||
2000-01-27 | Added note from Ian Lance Taylor <ian@zembu.com>. | Joel Sherrill | 1 | -2/+6 | |
2000-01-23 | Added rtems_task_variable_get from Eric Norum. | Joel Sherrill | 1 | -1/+48 | |
2000-01-23 | Updated to reflect changing to void * on task variables by | Joel Sherrill | 1 | -8/+10 | |
Eric Norum <eric@cls.usask.ca>. | |||||
2000-01-21 | Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> to | Joel Sherrill | 1 | -2/+11 | |
the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | |||||
2000-01-13 | Added POSIX interpretation subsection and updated status. | Joel Sherrill | 2 | -4/+16 | |
The message queue manager chapter needs to be updated to reflect completion of the implementation. | |||||
2000-01-04 | Fixed typos. | Joel Sherrill | 2 | -11/+12 | |
2000-01-04 | Updated dates and miscellaneous. | Joel Sherrill | 9 | -18/+27 | |
2000-01-04 | Added timer manager. | Joel Sherrill | 1 | -0/+5 | |
2000-01-04 | Improved clean stanza. | Joel Sherrill | 1 | -1/+1 | |
2000-01-03 | Added new URL. | Joel Sherrill | 1 | -0/+3 | |
1999-11-29 | Clarified. | Joel Sherrill | 1 | -0/+2 | |
1999-11-29 | Clarified status of mkfifo(). | Joel Sherrill | 1 | -0/+2 | |
1999-11-29 | Updated. | Joel Sherrill | 3 | -276/+324 | |
1999-11-29 | Removed bad descriptions of mount() and umount(). Added shell of an | Joel Sherrill | 1 | -124/+25 | |
accurate description. | |||||
1999-11-24 | Added chapter of list of routines provided by libm. | Joel Sherrill | 4 | -17/+102 | |
1999-11-24 | New file. | Joel Sherrill | 1 | -0/+154 | |
1999-11-24 | Added routines included by C library. | Joel Sherrill | 4 | -2/+336 | |
1999-11-24 | Added information on RTEMS Time/Date Representatin. | Joel Sherrill | 3 | -2/+120 | |
1999-11-23 | Added sem_timedwait to bullet list at front of chapter. | Joel Sherrill | 1 | -0/+1 | |
1999-11-23 | Added descriptions for bullet list and routine section headings. | Joel Sherrill | 1 | -8/+8 | |
1999-11-23 | Added Timer Manager Chapter. | Joel Sherrill | 2 | -1/+8 | |
1999-11-23 | Fixed line too long. | Joel Sherrill | 1 | -2/+2 | |
1999-11-23 | New file. | Joel Sherrill | 1 | -0/+196 | |
1999-11-23 | Added projects chapter to FAQ. | Joel Sherrill | 3 | -2/+122 | |
1999-11-17 | changed version to 19991117 | Joel Sherrill | 1 | -1/+1 | |
1999-11-17 | Removed reference to Jennifer. | Joel Sherrill | 1 | -2/+1 | |
1999-11-17 | New date. | Joel Sherrill | 2 | -5/+5 | |
1999-11-17 | Corrected spacing. | Joel Sherrill | 1 | -8/+12 | |
1999-11-17 | Correctd name of document produced for consistency. | Joel Sherrill | 1 | -1/+1 | |
1999-11-17 | Updated to reflect Mailbox Manager submission. | Joel Sherrill | 1 | -3/+1 | |
1999-11-16 | Fixed spacing. | Joel Sherrill | 12 | -175/+185 | |
1999-11-16 | Changed name of document generated. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Added ITRON 3.0 API User's Guide. | Joel Sherrill | 2 | -2/+12 | |
1999-11-16 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Corrected status. | Joel Sherrill | 1 | -2/+2 | |
1999-11-16 | Fixed spacing. | Joel Sherrill | 2 | -48/+48 | |
1999-11-16 | New file. | Joel Sherrill | 1 | -0/+14 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 308 | -372/+384 | |
