* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* user/io.t: Fix typo.
* user/io.t: Added error cases to rtems_io_register_driver.
* user/conf.t: Eliminate maximum_drivers configuration parameter since
it was used to configure a no longer used feature. Device names are
now part of the filesystem not in a table. This also eliminated the
variables _IO_Number_of_devices and _IO_Driver_name_table from RTEMS
as well as the memory allocation used to populate
_IO_Driver_name_table.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFER_MEMORY. Use
rtems/confdefs.h instead of old confdefs.h.
* user/conf.t: Fix typo -- should have read kilobytes.
* user/Makefile.am, user/concepts.t, user/rtmon.t: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* user/.cvsignore, user/cpuuse.t, user/stackchk.t: Stack checker and
CPU usage chapters are now OK in the manual.
* user/example.texi: Change all obsoleted CONFIGURE_TEST_NEEDS_XXX
configuration constants to CONFIGURE_APPLICATION_NEEDS_XXX.
* user/task.t: Add rtems_iterate_over_all_threads.
* user/clock.t: Add clock_get_uptime().
* user/Makefile.am, user/clock.t: Add support for a handler to obtain
the number of nanoseconds since the last clock tick. The primary
interface for this is rtems_clock_set_nanoseconds_extension.
Subsequent commits from Joel will redo the TOD support to use this
capability.
PR 1226/cpukit
* user/conf.t: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE not
CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE.
* user/Makefile.am, user/stackchk.t: Change dump usage to report usage.
* user/Makefile.am, user/barrier.t, user/c_user.texi: Update barrier
documentation.
PR 1221/doc
* user/rtmon.t: Add missing exponent operator in RMS CPU Utiliziation
formula.
* user/.cvsignore: Update.
* user/barrier.t: New file.
* new_chapters/Makefile.am, new_chapters/gen_section,
new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi,
user/dirstat.texi: Promote CPU Usage to first class citizen. Rename
to start with rtems_ and include documentation in user guide.
* user/cpuuse.t: New file.
* new_chapters/cpuuse.t: Removed.
* new_chapters/Makefile.am, user/Makefile.am, user/c_user.texi,
user/dirstat.texi, user/task.t: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
* user/stackchk.t: New file.
* new_chapters/stackchk.t: Removed.
PR 1171/doc
* user/timer.t: Correct documentation for rtems_timer_initiate_server.
* user/rtemsarc.gif, user/states.gif, user/rtemspie.gif:
Remove (Unused).
* user/rtemsarc.txt, user/rtemspie.txt, user/states.txt:
New (Extracted from other docs).
* user/Makefile.am: Reflect changes above.
* user/io.t: Change rtems_io_register_name to take a const char *.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
* user/region.t: Add documentation on region_resize_segment.
PR 706/doc
* user/task.t: Remove not that changes explanation.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
PR rtems/652
* user/signal.t: Return RTEMS_INVALID_NUMBER when sending an empty
signal set.
PR 631/rtems
* user/msg.t: Document the return status from message_queue_create when
unable to allocate message buffer memory.
PR 627/doc
* user/task.t: Behavior documented for an rtems_task_create with
stacksize < minimum was not the implemented behavior.
PR 618/rtems
* user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t,
user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL
checks.
* ChangeLog: Merge-in user/ChangeLog.
* user/ChangeLog: Remove.
* Makefile.am: Cosmetics.
PR 528/rtems_misc
* task.t: Fix Ada binding for task variable calls.
PR 521/doc
* sem.t: Default attributes were wrong for semaphores.
* preface.texi: Eliminate references to HPPA.
* c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch.
* fatal.t: Reflect c/src/exec having moved to cpukit.
* preface.texi: Remove a29k references and update.
PR 338/filesystem
* io.t: Fix Ada binding as side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
PR 338/filesystem
* io.t: Document the API change that fixed reentrancy problem with
rtems_io_lookup_name().
* c_user.texi: Set @setfilename c_user.info.
