PR 1226/cpukit
* user/conf.t: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE not
CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE.
* user/Makefile.am, user/stackchk.t: Change dump usage to report usage.
* user/Makefile.am, user/barrier.t, user/c_user.texi: Update barrier
documentation.
PR 1221/doc
* user/rtmon.t: Add missing exponent operator in RMS CPU Utiliziation
formula.
* user/.cvsignore: Update.
* user/barrier.t: New file.
* new_chapters/Makefile.am, new_chapters/gen_section,
new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi,
user/dirstat.texi: Promote CPU Usage to first class citizen. Rename
to start with rtems_ and include documentation in user guide.
* user/cpuuse.t: New file.
* new_chapters/cpuuse.t: Removed.
* new_chapters/Makefile.am, user/Makefile.am, user/c_user.texi,
user/dirstat.texi, user/task.t: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
* user/stackchk.t: New file.
* new_chapters/stackchk.t: Removed.
PR 1171/doc
* user/timer.t: Correct documentation for rtems_timer_initiate_server.
* user/rtemsarc.gif, user/states.gif, user/rtemspie.gif:
Remove (Unused).
* user/rtemsarc.txt, user/rtemspie.txt, user/states.txt:
New (Extracted from other docs).
* user/Makefile.am: Reflect changes above.
* user/io.t: Change rtems_io_register_name to take a const char *.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
* user/region.t: Add documentation on region_resize_segment.
PR 706/doc
* user/task.t: Remove not that changes explanation.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
PR rtems/652
* user/signal.t: Return RTEMS_INVALID_NUMBER when sending an empty
signal set.
PR 631/rtems
* user/msg.t: Document the return status from message_queue_create when
unable to allocate message buffer memory.
PR 627/doc
* user/task.t: Behavior documented for an rtems_task_create with
stacksize < minimum was not the implemented behavior.
PR 618/rtems
* user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t,
user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL
checks.
* ChangeLog: Merge-in user/ChangeLog.
* user/ChangeLog: Remove.
* Makefile.am: Cosmetics.
PR 528/rtems_misc
* task.t: Fix Ada binding for task variable calls.
PR 521/doc
* sem.t: Default attributes were wrong for semaphores.
* preface.texi: Eliminate references to HPPA.
* c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch.
* fatal.t: Reflect c/src/exec having moved to cpukit.
* preface.texi: Remove a29k references and update.
PR 338/filesystem
* io.t: Fix Ada binding as side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
PR 338/filesystem
* io.t: Document the API change that fixed reentrancy problem with
rtems_io_lookup_name().
* c_user.texi: Set @setfilename c_user.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* io.t: Correct Ada bindings.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* doc/user/userext.t: Per PR138, updated the documentation to show
how to obtain an extension table index. Also provided some extra
background on the user extension API.
* io.t: Fix typo @sybsection.
* intr.t: Per PR165, now correctly states that passing a NULL
pointer for the return argument is an error.
