PR 1743/cpu
* user/conf.t: Add Simple Priority Scheduler as complement to existing
Deterministic Priority Scheduler. This scheduler serves both as an
example and as a lighter weight implementation for smaller systems.
PR 1744/doc
* user/clock.t: rtems_clock_time_value type uses changed to struct
timeval.
* user/conf.t: Document changes to Scheduler configuration.
PR 1647/cpukit
* user/conf.t, user/schedule.t: Update documentation to reflect
refactoring of SuperCore to add Scheduler and ability for user to
configure a scheduler.
PR 1716/doc
* user/concepts.t: print_name example used a variable which did not
match the name of the passed in parameter.
PR 1714/doc
* user/datatypes.t: Add missing description of rtems_status_codes.
PR 1674/docs
* user/Makefile.am, user/dirstat.texi: Fix bad node reference.
PR 1513/doc
* user/chains.t: Added missing functions. Uniform text for
unprotected functions.
PR 1650/cpukit
* user/part.t: Clarify.
* Makefile.am, configure.ac, index.html.in, develenv/direct.t,
posix_users/gen_size_report, started/nextstep.t,
started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API.
* itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t,
itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all,
itron3.0/gen_section, itron3.0/gen_status_shell,
itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t,
itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t,
itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t,
itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t,
itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
PR 1568/doc
* user/intr.t: Fix list of services callable from ISR.
* user/.cvsignore: Add semaphore_attributes.pdf.
PR 1520/doc
* user/part.t: Partition create discussion said it returned the number
of buffers created but it does not.
PR 1519/doc
* user/chains.t: Fix typo in Chain_Control example.
PR 1510/doc
* user/chains.t: Fix code example.
* user/chain.t: Fixed the example from PR 1504.
* user/conf.t: CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
PR 1490/doc
* user/clock.t: Fix typo. rtems_clock_get_ticks_per_second not
rtems_clock_get_ticks_per_seconds.
* user/clock.t: Eliminate unused type rtems_clock_time_value.
PR 1460/cpukit
* user/object.t: Change return type on methods accessing portions of
RTEMS Ids to int. This allows -1 to be return on error.
* ada_user/Makefile.am, ada_user/ada_user.texi, user/Makefile.am,
user/c_user.texi, user/concepts.t, user/overview.t,
user/preface.texi, user/schedule.t, user/sem.t: Add table of figures.
Add text and graphic of tree illustrating valid combinations of
semaphore attributes.
* user/semaphore_attributes.eps, user/semaphore_attributes.png:
New files.
* user/preface.texi: Remove UNIX and update port list.
* user/conf.t, user/userext.t: Eliminate use of deprecated
rtems_extension.
* user/conf.t: Change stack allocator signature.
* user/conf.t: Add configuration of posix message queue file
descriptors as separate entity. Also add documentation on posix
configuration elements not previously covered.
* bsp_howto/.cvsignore, bsp_howto/Makefile.am,
bsp_howto/bsp_howto.texi: Add Frame Buffer Device Driver shell.
* bsp_howto/framebuffer.t: New file.
* user/conf.t: Add CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER.
* user/region.t: Fix typos where semaphore referenced instead of region
or segment.
* user/preface.texi: Correct list of supported CPU architectures.
* user/conf.t: Change work_space_size to uintptr_t since it cannot be
negative.
* user/.cvsignore: Add Object ID PDF files.
PR 1387/doc
* user/intr.t: Add Interrupt Manager services to list of services
callable from ISR.
* bsp_howto/console.t: Clarify interrupt transmit process.
* user/concepts.t: Typo.
* user/cpuuse.t: Reflect change in CPU Usage report format.
* user/init.t: Eliminate pointers to API configuration tables in the
main configuration table. Reference the main configuration table and
the API configuration tables directly using the confdefs.h version
rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* user/conf.t, user/region.t: Change sizes of heap/region and allocated
objects in heap to intptr_t so they can be larger than a single
allocatable object (e.g. size_t).
* user/region.t: Malloc Family is not implemented in termios of Region
Manager after 4.7. Correct documentation.
* ada_user/Makefile.am, user/Makefile.am, user/concepts.t: Add 16 bit
object Id format information.
* user/ObjectId-16Bits.eps, user/ObjectId-16Bits.png: New files.
* user/datatypes.t: Add C99 uint types.
PR 1340/cpukit
* user/chains.t: Add rtems_chain_initialize to public chain API.
PR 1339/Ada
* user/io.t: Re-add IO Manager to Ada binding.
PR 1336/cpukit
* user/chains.t, user/dirstat.texi: Add rtems_chain_prepend_unprotected
and rtems_chain_append_unprotected.
* user/concepts.t: Use 32 bit version centered.
PR 1334/doc
* user/Makefile.am, user/concepts.t, user/init.t, user/overview.t,
user/part.t, user/task.t: Correct typos and correctly document 4
parts of 32-bit object id.
* user/ObjectId-32Bits.eps, user/ObjectId-32Bits.png: New files.
* user/conf.t: Fix typo.
* user/region.t: Change size_t to ssize_t.
* user/conf.t: Add CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM and
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* shell/rtems.t, user/conf.t, user/stackchk.t: Rename STACK_CHECKER_ON
to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
