* | Spacing. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1998-10-09 | 1 | -1/+1 |
* | Added text to clarify the queueing of multiple events. | Joel Sherrill | 1998-08-13 | 1 | -12/+12 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -12/+19 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 2 | -5/+7 |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 18 | -4/+98 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -2/+2 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -2/+3 |
* | Added dependency so html would build from scratch. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 24 | -1883/+176 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 22 | -613/+830 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 17 | -554/+554 |
* | Added Hitachi SH | Joel Sherrill | 1998-03-27 | 6 | -58/+60 |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 9 | -89/+160 |
| | | | | and all directives start with rtems_. | ||||
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 28 | -34/+28 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 2 | -5/+6 |
* | More specific information on error code. | Joel Sherrill | 1997-09-03 | 1 | -1/+2 |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 7 | -11/+57 |
* | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1997-07-31 | 1 | -0/+36 |
| | | | | for the pointer to a "return area".. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 1 | -5/+50 |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 28 | -0/+56 |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 9 | -27/+26 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 22 | -206/+388 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | fixed typos | Joel Sherrill | 1997-05-30 | 4 | -9/+9 |
* | updated to reflect Ada | Joel Sherrill | 1997-05-30 | 2 | -15/+262 |
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 22 | -46/+1322 |
* | version changed | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 31 | -0/+13201 |
