* | Corrected a typo. | Joel Sherrill | 1999-10-06 | 2 | -21/+23 | |
* | Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' | Joel Sherrill | 1999-10-01 | 1 | -3/+3 | |
| | | | | <ccj@acm.org> suggestion. | |||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 8 | -11/+17 | |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
* | Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1999-10-01 | 1 | -0/+10 | |
* | Added a lot of information on confdefs.t | Joel Sherrill | 1999-07-03 | 1 | -16/+367 | |
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 | |
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 | |
* | Corrected formatting so argument was in code font. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 | |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 | |
* | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1999-04-19 | 1 | -12/+36 | |
* | Added maximum_timers field to configuration table. | Joel Sherrill | 1999-02-09 | 1 | -1/+1 | |
* | Added POSIX timers. | Joel Sherrill | 1999-02-03 | 1 | -0/+6 | |
* | Updated to correct information on post switch extension and to make | Joel Sherrill | 1998-12-17 | 1 | -41/+8 | |
| | | | | the user extension table type definition correct. | |||||
* | Corrected information about the post_switch extension. | Joel Sherrill | 1998-12-17 | 1 | -7/+0 | |
* | Spacing. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 | |
* | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1998-10-09 | 1 | -1/+1 | |
* | Added text to clarify the queueing of multiple events. | Joel Sherrill | 1998-08-13 | 1 | -12/+12 | |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -12/+19 | |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 2 | -5/+7 | |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | |||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 18 | -4/+98 | |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 | |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -2/+2 | |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -2/+3 | |
* | Added dependency so html would build from scratch. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 | |
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 24 | -1883/+176 | |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 22 | -613/+830 | |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 17 | -554/+554 | |
* | Added Hitachi SH | Joel Sherrill | 1998-03-27 | 6 | -58/+60 | |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 9 | -89/+160 | |
| | | | | and all directives start with rtems_. | |||||
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 | |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 28 | -34/+28 | |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 2 | -5/+6 | |
* | More specific information on error code. | Joel Sherrill | 1997-09-03 | 1 | -1/+2 | |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 7 | -11/+57 | |
* | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1997-07-31 | 1 | -0/+36 | |
| | | | | for the pointer to a "return area".. | |||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 1 | -5/+50 | |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 | |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 28 | -0/+56 | |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 1 | -2/+2 | |
* | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1997-06-04 | 1 | -2/+2 | |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 9 | -27/+26 | |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 22 | -206/+388 | |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
* | fixed typos | Joel Sherrill | 1997-05-30 | 4 | -9/+9 | |
* | updated to reflect Ada | Joel Sherrill | 1997-05-30 | 2 | -15/+262 | |
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 22 | -46/+1322 | |
* | version changed | Joel Sherrill | 1997-05-28 | 1 | -2/+2 | |
* | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 1 | -2/+2 | |
* | Initial revision | Joel Sherrill | 1997-05-27 | 31 | -0/+13201 | |
