* user/io.t: Change rtems_io_register_name to take a const char *.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
* user/region.t: Add documentation on region_resize_segment.
PR 706/doc
* user/task.t: Remove not that changes explanation.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
PR rtems/652
* user/signal.t: Return RTEMS_INVALID_NUMBER when sending an empty
signal set.
PR 631/rtems
* user/msg.t: Document the return status from message_queue_create when
unable to allocate message buffer memory.
PR 627/doc
* user/task.t: Behavior documented for an rtems_task_create with
stacksize < minimum was not the implemented behavior.
PR 618/rtems
* user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t,
user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL
checks.
* ChangeLog: Merge-in user/ChangeLog.
* user/ChangeLog: Remove.
* Makefile.am: Cosmetics.
PR 528/rtems_misc
* task.t: Fix Ada binding for task variable calls.
PR 521/doc
* sem.t: Default attributes were wrong for semaphores.
* preface.texi: Eliminate references to HPPA.
* c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch.
* fatal.t: Reflect c/src/exec having moved to cpukit.
* preface.texi: Remove a29k references and update.
PR 338/filesystem
* io.t: Fix Ada binding as side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
PR 338/filesystem
* io.t: Document the API change that fixed reentrancy problem with
rtems_io_lookup_name().
* c_user.texi: Set @setfilename c_user.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* io.t: Correct Ada bindings.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* doc/user/userext.t: Per PR138, updated the documentation to show
how to obtain an extension table index. Also provided some extra
background on the user extension API.
* io.t: Fix typo @sybsection.
* intr.t: Per PR165, now correctly states that passing a NULL
pointer for the return argument is an error.
* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* rtmon.t: Correct example and correctly used ensure not insure.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
