PR 528/rtems_misc
* task.t: Fix Ada binding for task variable calls.
PR 521/doc
* sem.t: Default attributes were wrong for semaphores.
* preface.texi: Eliminate references to HPPA.
* c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch.
* fatal.t: Reflect c/src/exec having moved to cpukit.
* preface.texi: Remove a29k references and update.
PR 338/filesystem
* io.t: Fix Ada binding as side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
PR 338/filesystem
* io.t: Document the API change that fixed reentrancy problem with
rtems_io_lookup_name().
* c_user.texi: Set @setfilename c_user.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* io.t: Correct Ada bindings.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* doc/user/userext.t: Per PR138, updated the documentation to show
how to obtain an extension table index. Also provided some extra
background on the user extension API.
* io.t: Fix typo @sybsection.
* intr.t: Per PR165, now correctly states that passing a NULL
pointer for the return argument is an error.
* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* rtmon.t: Correct example and correctly used ensure not insure.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
over number of termios ports.
structure.
