* | Fixed variable reference for RTEMS-RELEASE. | Joel Sherrill | 1999-10-11 | 1 | -1/+1 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+2 |
| | | | | | | pdf version of figures. Added convert stanza to generate pdf's from eps of figures. | ||||
* | Regenerated. | Joel Sherrill | 1999-10-07 | 2 | -0/+0 |
* | New files. | Joel Sherrill | 1999-10-07 | 2 | -0/+0 |
* | Added rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 1 | -0/+42 |
* | Cleaned up use of $(PROJECT) instead of hard-coding c_user. | Joel Sherrill | 1999-10-07 | 1 | -3/+5 |
| | | | | Added rule to convert rtemspie.eps to .pdf. | ||||
* | Enabled images. They appear to work ok for PostScript but not as well | Joel Sherrill | 1999-10-06 | 5 | -24/+13845 |
| | | | | for PDF -- at least according to ghostview. | ||||
* | Added multiple formats of the image so we can use the @image command. | Joel Sherrill | 1999-10-06 | 3 | -0/+2164 |
* | Corrected a typo. | Joel Sherrill | 1999-10-06 | 2 | -21/+23 |
* | Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' | Joel Sherrill | 1999-10-01 | 1 | -3/+3 |
| | | | | <ccj@acm.org> suggestion. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 8 | -11/+17 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1999-10-01 | 1 | -0/+10 |
* | Added a lot of information on confdefs.t | Joel Sherrill | 1999-07-03 | 1 | -16/+367 |
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 |
* | Corrected formatting so argument was in code font. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 |
* | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1999-04-19 | 1 | -12/+36 |
* | Added maximum_timers field to configuration table. | Joel Sherrill | 1999-02-09 | 1 | -1/+1 |
* | Added POSIX timers. | Joel Sherrill | 1999-02-03 | 1 | -0/+6 |
* | Updated to correct information on post switch extension and to make | Joel Sherrill | 1998-12-17 | 1 | -41/+8 |
| | | | | the user extension table type definition correct. | ||||
* | Corrected information about the post_switch extension. | Joel Sherrill | 1998-12-17 | 1 | -7/+0 |
* | Spacing. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1998-10-09 | 1 | -1/+1 |
* | Added text to clarify the queueing of multiple events. | Joel Sherrill | 1998-08-13 | 1 | -12/+12 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -12/+19 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 2 | -5/+7 |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 18 | -4/+98 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -2/+2 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -2/+3 |
* | Added dependency so html would build from scratch. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 24 | -1883/+176 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 22 | -613/+830 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 17 | -554/+554 |
* | Added Hitachi SH | Joel Sherrill | 1998-03-27 | 6 | -58/+60 |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 9 | -89/+160 |
| | | | | and all directives start with rtems_. | ||||
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 28 | -34/+28 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 2 | -5/+6 |
* | More specific information on error code. | Joel Sherrill | 1997-09-03 | 1 | -1/+2 |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 7 | -11/+57 |
* | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1997-07-31 | 1 | -0/+36 |
| | | | | for the pointer to a "return area".. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 1 | -5/+50 |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 28 | -0/+56 |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 9 | -27/+26 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 22 | -206/+388 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" |
