2000-04-27 | New files. First attempt. | Joel Sherrill | 1 | -0/+55 | |
2000-04-26 | Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -32/+37 | |
that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document. | |||||
2000-04-26 | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -76/+39 | |
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | |||||
2000-04-25 | Merged changes from 4.5 branch and removed that branch. | Joel Sherrill | 1 | -2/+2 | |
2000-02-29 | Eric Norum spotted this sentence where it said preemption had to be | Joel Sherrill | 1 | -1/+3 | |
disabled for timeslicing to happen. This was wrong. | |||||
2000-02-18 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
2000-02-18 | Patch from Eric Norum <eric@cls.usask.ca> to include some information | Joel Sherrill | 1 | -0/+8 | |
on simple binary semaphores. | |||||
2000-01-27 | Added note from Ian Lance Taylor <ian@zembu.com>. | Joel Sherrill | 1 | -2/+6 | |
2000-01-23 | Added rtems_task_variable_get from Eric Norum. | Joel Sherrill | 1 | -1/+48 | |
2000-01-23 | Updated to reflect changing to void * on task variables by | Joel Sherrill | 1 | -8/+10 | |
Eric Norum <eric@cls.usask.ca>. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 28 | -28/+28 | |
1999-11-16 | Added reference to rtems_get_class, rtems_get_node, and rtems_get_index | Joel Sherrill | 1 | -7/+29 | |
so users know they are part of the public API. | |||||
1999-11-16 | Added task variable services. | Joel Sherrill | 2 | -1/+131 | |
1999-11-16 | Added categorized list of constants in confdefs.h. | Joel Sherrill | 1 | -0/+126 | |
1999-10-25 | Fixed line too long problems. | Joel Sherrill | 2 | -13/+20 | |
1999-10-25 | Formatting improvements. | Joel Sherrill | 3 | -12/+80 | |
1999-10-11 | Added files generated by index process to clean stanza. | Joel Sherrill | 1 | -1/+3 | |
1999-10-11 | Corrected spacing. | Joel Sherrill | 1 | -1/+0 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 23 | -154/+771 | |
1999-10-11 | Fixed variable reference for RTEMS-RELEASE. | Joel Sherrill | 1 | -1/+1 | |
1999-10-07 | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1 | -1/+2 | |
pdf version of figures. Added convert stanza to generate pdf's from eps of figures. | |||||
1999-10-07 | Regenerated. | Joel Sherrill | 2 | -0/+0 | |
1999-10-07 | New files. | Joel Sherrill | 2 | -0/+0 | |
1999-10-07 | Added rtems_task_is_suspended. | Joel Sherrill | 1 | -0/+42 | |
1999-10-07 | Cleaned up use of $(PROJECT) instead of hard-coding c_user. | Joel Sherrill | 1 | -3/+5 | |
Added rule to convert rtemspie.eps to .pdf. | |||||
1999-10-06 | Enabled images. They appear to work ok for PostScript but not as well | Joel Sherrill | 5 | -24/+13845 | |
for PDF -- at least according to ghostview. | |||||
1999-10-06 | Added multiple formats of the image so we can use the @image command. | Joel Sherrill | 3 | -0/+2164 | |
1999-10-06 | Corrected a typo. | Joel Sherrill | 2 | -21/+23 | |
1999-10-01 | Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' | Joel Sherrill | 1 | -3/+3 | |
<ccj@acm.org> suggestion. | |||||
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 8 | -11/+17 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1999-10-01 | Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1 | -0/+10 | |
1999-07-03 | Added a lot of information on confdefs.t | Joel Sherrill | 1 | -16/+367 | |
1999-07-03 | Removed concept of distribution level. | Joel Sherrill | 1 | -1/+0 | |
1999-07-01 | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1 | -0/+1 | |
1999-07-01 | Corrected formatting so argument was in code font. | Joel Sherrill | 1 | -1/+1 | |
1999-07-01 | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1 | -1/+2 | |
1999-04-19 | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1 | -12/+36 | |
1999-02-09 | Added maximum_timers field to configuration table. | Joel Sherrill | 1 | -1/+1 | |
1999-02-03 | Added POSIX timers. | Joel Sherrill | 1 | -0/+6 | |
1998-12-17 | Updated to correct information on post switch extension and to make | Joel Sherrill | 1 | -41/+8 | |
the user extension table type definition correct. | |||||
1998-12-17 | Corrected information about the post_switch extension. | Joel Sherrill | 1 | -7/+0 | |
1998-10-27 | Spacing. | Joel Sherrill | 1 | -1/+1 | |
1998-10-09 | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1 | -1/+1 | |
1998-08-13 | Added text to clarify the queueing of multiple events. | Joel Sherrill | 1 | -12/+12 | |
1998-04-15 | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1 | -12/+19 | |
to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
1998-04-02 | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 2 | -5/+7 | |
but do not print them. texi2dvi barfs if the entries are even there. | |||||
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 18 | -4/+98 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-30 | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1 | -15/+7 | |
1998-03-30 | Corrected distribution levels for html | Joel Sherrill | 1 | -2/+2 | |
1998-03-30 | Added distribution level to each manual | Joel Sherrill | 1 | -2/+3 | |
