1999-07-03 | Added a lot of information on confdefs.t | Joel Sherrill | 1 | -16/+367 | |
1999-07-03 | Removed concept of distribution level. | Joel Sherrill | 1 | -1/+0 | |
1999-07-01 | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1 | -0/+1 | |
1999-07-01 | Corrected formatting so argument was in code font. | Joel Sherrill | 1 | -1/+1 | |
1999-07-01 | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1 | -1/+2 | |
1999-04-19 | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1 | -12/+36 | |
1999-02-09 | Added maximum_timers field to configuration table. | Joel Sherrill | 1 | -1/+1 | |
1999-02-03 | Added POSIX timers. | Joel Sherrill | 1 | -0/+6 | |
1998-12-17 | Updated to correct information on post switch extension and to make | Joel Sherrill | 1 | -41/+8 | |
the user extension table type definition correct. | |||||
1998-12-17 | Corrected information about the post_switch extension. | Joel Sherrill | 1 | -7/+0 | |
1998-10-27 | Spacing. | Joel Sherrill | 1 | -1/+1 | |
1998-10-09 | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1 | -1/+1 | |
1998-08-13 | Added text to clarify the queueing of multiple events. | Joel Sherrill | 1 | -12/+12 | |
1998-04-15 | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1 | -12/+19 | |
to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
1998-04-02 | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 2 | -5/+7 | |
but do not print them. texi2dvi barfs if the entries are even there. | |||||
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 18 | -4/+98 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-30 | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1 | -15/+7 | |
1998-03-30 | Corrected distribution levels for html | Joel Sherrill | 1 | -2/+2 | |
1998-03-30 | Added distribution level to each manual | Joel Sherrill | 1 | -2/+3 | |
1998-03-27 | Added dependency so html would build from scratch. | Joel Sherrill | 1 | -1/+1 | |
1998-03-27 | Nodes, menus, etc are automatically generated now | Joel Sherrill | 24 | -1883/+176 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 22 | -613/+830 | |
1998-03-27 | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 17 | -554/+554 | |
1998-03-27 | Added Hitachi SH | Joel Sherrill | 6 | -58/+60 | |
1998-03-27 | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 9 | -89/+160 | |
and all directives start with rtems_. | |||||
1998-03-26 | Added variables for dates and revision info | Joel Sherrill | 1 | -4/+4 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 28 | -34/+28 | |
1998-01-23 | minor updates .. mostly version | Joel Sherrill | 2 | -5/+6 | |
1997-09-03 | More specific information on error code. | Joel Sherrill | 1 | -1/+2 | |
1997-08-04 | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 7 | -11/+57 | |
1997-07-31 | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1 | -0/+36 | |
for the pointer to a "return area".. | |||||
1997-07-31 | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1 | -5/+50 | |
1997-07-18 | Fixed typo of "::" | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 28 | -0/+56 | |
1997-06-04 | changed edition and version information | Joel Sherrill | 1 | -2/+2 | |
1997-06-04 | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1 | -2/+2 | |
1997-06-04 | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 9 | -27/+26 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 22 | -206/+388 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-30 | fixed typos | Joel Sherrill | 4 | -9/+9 | |
1997-05-30 | updated to reflect Ada | Joel Sherrill | 2 | -15/+262 | |
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 22 | -46/+1322 | |
1997-05-28 | version changed | Joel Sherrill | 1 | -2/+2 | |
1997-05-28 | 4.0.0 release docs | Joel Sherrill | 1 | -2/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 31 | -0/+13201 | |
