path: root/doc/user/userext.t (follow)
* 2009-09-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-261-7/+7
| | | | | * user/conf.t, user/userext.t: Eliminate use of deprecated rtems_extension.
* More "bool" cleanup.Ralf Corsepius2008-09-091-4/+4
* Convert to "bool".Ralf Corsepius2008-09-091-1/+1
* 2008-08-21 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-08-211-1/+1
| | | | | | | * bsp_howto/ata.t, bsp_howto/clock.t, bsp_howto/ide-ctrl.t, bsp_howto/nvmem.t, bsp_howto/shmsupp.t, user/datatypes.t, user/mp.t, user/userext.t: Eliminate all references to rtems_signedXX and rtems_unsignedXX.
* 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-291-1/+1
| | | | | | | | * user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t, user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t, user/userext.t: Add new Object Services collection. Tidy up some configuration documentation from earlier changes. * user/object.t: New file.
* 2002-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-281-6/+16
| | | | | | * userext.t: Per PR228, correct the prototype of the task create user extension to indicate it returns a boolean and augment the documentation to explain the purpose of the boolean return value.
* 2002-04-12 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-131-2/+28
| | | | | | * doc/user/userext.t: Per PR138, updated the documentation to show how to obtain an extension table index. Also provided some extra background on the user extension API.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-13/+19
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Turned on concept and function name indexing.Joel Sherrill1999-10-111-3/+25
* Updated to correct information on post switch extension and to makeJoel Sherrill1998-12-171-41/+8
| | | | the user extension table type definition correct.
* Added "findex" for all directive pages but it turns out that thisJoel Sherrill1998-04-021-0/+3
| | | | blows up both makeinfo and texi2dvi. So I have commented them out.
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-113/+2
* Completed sweep adding directive and constant prefixes.Joel Sherrill1998-03-271-7/+9
* Conditionally adding RTEMS_ and rtems_ prefixes.Joel Sherrill1998-03-271-11/+11
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* final corrections before 4.1.0 documentation freeze.Joel Sherrill1997-06-041-1/+1
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-3/+3
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* first cut at Ada bindings manualJoel Sherrill1997-05-291-10/+161
* Initial revisionJoel Sherrill1997-05-271-0/+649
