* | More "bool" cleanup. | Ralf Corsepius | 2008-09-09 | 1 | -4/+4 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-09 | 1 | -1/+1 |
* | 2008-08-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-21 | 1 | -1/+1 |
| | | | | | | | * bsp_howto/ata.t, bsp_howto/clock.t, bsp_howto/ide-ctrl.t, bsp_howto/nvmem.t, bsp_howto/shmsupp.t, user/datatypes.t, user/mp.t, user/userext.t: Eliminate all references to rtems_signedXX and rtems_unsignedXX. | ||||
* | 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-29 | 1 | -1/+1 |
| | | | | | | | | * user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t, user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t, user/userext.t: Add new Object Services collection. Tidy up some configuration documentation from earlier changes. * user/object.t: New file. | ||||
* | 2002-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -6/+16 |
| | | | | | | * userext.t: Per PR228, correct the prototype of the task create user extension to indicate it returns a boolean and augment the documentation to explain the purpose of the boolean return value. | ||||
* | 2002-04-12 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-04-13 | 1 | -2/+28 |
| | | | | | | * doc/user/userext.t: Per PR138, updated the documentation to show how to obtain an extension table index. Also provided some extra background on the user extension API. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -13/+19 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 1 | -3/+25 |
* | Updated to correct information on post switch extension and to make | Joel Sherrill | 1998-12-17 | 1 | -41/+8 |
| | | | | the user extension table type definition correct. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+3 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -113/+2 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -7/+9 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -11/+11 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 1 | -1/+1 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -3/+3 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -10/+161 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+649 |
