* | Updated to correct information on post switch extension and to make | Joel Sherrill | 1998-12-17 | 1 | -41/+8 |
| | | | | the user extension table type definition correct. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+3 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -113/+2 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -7/+9 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -11/+11 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 1 | -1/+1 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -3/+3 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -10/+161 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+649 |
