1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-08-04 | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1 | -5/+23 | |
1997-07-18 | Fixed typo of "::" | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -1/+1 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -2/+96 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+441 | |
