* | 2003-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-11-25 | 1 | -10/+15 |
| | | | | | PR 528/rtems_misc * task.t: Fix Ada binding for task variable calls. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Added comment on RTEMS_DEFAULT_MODE. | Joel Sherrill | 2000-05-09 | 1 | -0/+3 |
* | Fixed type so constant would have "RTEMS_" in front of it. | Joel Sherrill | 2000-05-08 | 1 | -1/+1 |
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -8/+22 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | A bit more explanation for task variables per Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 2000-05-01 | 1 | -0/+7 |
* | Eric Norum spotted this sentence where it said preemption had to be | Joel Sherrill | 2000-02-29 | 1 | -1/+3 |
| | | | | disabled for timeslicing to happen. This was wrong. | ||||
* | Fixed typo. | Joel Sherrill | 2000-02-18 | 1 | -1/+1 |
* | Added note from Ian Lance Taylor <ian@zembu.com>. | Joel Sherrill | 2000-01-27 | 1 | -2/+6 |
* | Added rtems_task_variable_get from Eric Norum. | Joel Sherrill | 2000-01-23 | 1 | -1/+48 |
* | Updated to reflect changing to void * on task variables by | Joel Sherrill | 2000-01-23 | 1 | -8/+10 |
| | | | | Eric Norum <eric@cls.usask.ca>. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added task variable services. | Joel Sherrill | 1999-11-16 | 1 | -0/+130 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 1 | -14/+77 |
* | Added rtems_task_is_suspended. | Joel Sherrill | 1999-10-07 | 1 | -0/+42 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -2/+2 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1999-07-01 | 1 | -0/+1 |
* | Spacing. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+23 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -169/+0 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -211/+269 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -151/+151 |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 1 | -31/+63 |
| | | | | and all directives start with rtems_. | ||||
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -7/+1 |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 1 | -0/+13 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 1 | -1/+1 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -43/+44 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -0/+173 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+1313 |
