2000-02-29 | Eric Norum spotted this sentence where it said preemption had to be | Joel Sherrill | 1 | -1/+3 | |
disabled for timeslicing to happen. This was wrong. | |||||
2000-02-18 | Fixed typo. | Joel Sherrill | 1 | -1/+1 | |
2000-01-27 | Added note from Ian Lance Taylor <ian@zembu.com>. | Joel Sherrill | 1 | -2/+6 | |
2000-01-23 | Added rtems_task_variable_get from Eric Norum. | Joel Sherrill | 1 | -1/+48 | |
2000-01-23 | Updated to reflect changing to void * on task variables by | Joel Sherrill | 1 | -8/+10 | |
Eric Norum <eric@cls.usask.ca>. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Added task variable services. | Joel Sherrill | 1 | -0/+130 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 1 | -14/+77 | |
1999-10-07 | Added rtems_task_is_suspended. | Joel Sherrill | 1 | -0/+42 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -2/+2 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1999-07-01 | Added error status for bad return pointer argument on rtems_task_set_priority. | Joel Sherrill | 1 | -0/+1 | |
1998-10-27 | Spacing. | Joel Sherrill | 1 | -1/+1 | |
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1 | -0/+23 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-27 | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1 | -169/+0 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1 | -211/+269 | |
1998-03-27 | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1 | -151/+151 | |
1998-03-27 | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1 | -31/+63 | |
and all directives start with rtems_. | |||||
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -7/+1 | |
1997-08-04 | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1 | -0/+13 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1 | -1/+1 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -43/+44 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -0/+173 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+1313 | |
