* ada_user/Makefile.am, ada_user/ada_user.texi, user/Makefile.am,
user/c_user.texi, user/concepts.t, user/overview.t,
user/preface.texi, user/schedule.t, user/sem.t: Add table of figures.
Add text and graphic of tree illustrating valid combinations of
semaphore attributes.
* user/semaphore_attributes.eps, user/semaphore_attributes.png:
New files.
* user/msg.t, user/sem.t, user/task.t: Update to new parameter types.
Emphasize that you can use a pointer for task arguments.
* user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t,
user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t:
Correct documentation typos noticed and thankfully reported by
FabrÃcio de Novaes Kucinskis <fabricio@dea.inpe.br>
* user/barrier.t, user/clock.t, user/concepts.t, user/conf.t,
user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t,
user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t,
user/task.t, user/timer.t: Corrected various errors in the
documentation.
* user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t,
user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t,
user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the
Ada documentation to reflect the current binding.
PR 618/rtems
* user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t,
user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL
checks.
PR 521/doc
* sem.t: Default attributes were wrong for semaphores.
on simple binary semaphores.
figures included.
blows up both makeinfo and texi2dvi. So I have commented them out.
and all directives start with rtems_.
to be correct in either C or Ada.
Added the interrupt disable, enable, flash, and is in progress directives.
changed "97" to "1997"
