2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -2/+3 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-25 | Fixed line too long problems. | Joel Sherrill | 1 | -2/+2 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 1 | -7/+58 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -1/+1 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1998-10-09 | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1 | -1/+1 | |
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1 | -0/+6 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-27 | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1 | -137/+2 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1 | -36/+46 | |
1998-03-27 | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1 | -29/+29 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-09-03 | More specific information on error code. | Joel Sherrill | 1 | -1/+2 | |
1997-08-04 | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1 | -3/+11 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1 | -1/+1 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -6/+6 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -1/+84 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+1148 | |
