path: root/doc/user/preface.texi (follow)
* Fixed variable reference for RTEMS-RELEASE.Joel Sherrill1999-10-111-1/+1
* Added Hitachi SHJoel Sherrill1998-03-271-0/+1
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-1/+1
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* first cut at Ada bindings manualJoel Sherrill1997-05-291-7/+20
* Initial revisionJoel Sherrill1997-05-271-0/+173
