closes #2812.
* ada_user/Makefile.am, ada_user/ada_user.texi, user/Makefile.am,
user/c_user.texi, user/concepts.t, user/overview.t,
user/preface.texi, user/schedule.t, user/sem.t: Add table of figures.
Add text and graphic of tree illustrating valid combinations of
semaphore attributes.
* user/semaphore_attributes.eps, user/semaphore_attributes.png:
New files.
PR 1334/doc
* user/Makefile.am, user/concepts.t, user/init.t, user/overview.t,
user/part.t, user/task.t: Correct typos and correctly document 4
parts of 32-bit object id.
* user/ObjectId-32Bits.eps, user/ObjectId-32Bits.png: New files.
* user/bsp.t, user/conf.t, user/init.t, user/intr.t, user/overview.t,
user/timer.t: Correct default values. Make it clear that confdefs.h
calculates the memory required for you.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
for PDF -- at least according to ghostview.
to be correct in either C or Ada.
Added the interrupt disable, enable, flash, and is in progress directives.
changed "97" to "1997"
