2008-08-08 | 2008-08-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 1 | -13/+14 | |
* user/msg.t, user/sem.t, user/task.t: Update to new parameter types. Emphasize that you can use a pointer for task arguments. | |||||
2008-08-01 | 2008-08-01 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* user/msg.t: Parameter is size not count. Spotted by Sebastian Huber. | |||||
2008-07-15 | 2008-07-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Correct documentation typos noticed and thankfully reported by FabrÃcio de Novaes Kucinskis <fabricio@dea.inpe.br> | |||||
2007-11-28 | 2007-11-28 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 1 | -24/+24 | |
* user/barrier.t, user/clock.t, user/concepts.t, user/conf.t, user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Corrected various errors in the documentation. | |||||
2004-06-29 | 2004-06-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+3 | |
PR 631/rtems * user/msg.t: Document the return status from message_queue_create when unable to allocate message buffer memory. | |||||
2004-05-06 | 2004-05-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+10 | |
PR 618/rtems * user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t, user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL checks. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 1 | -9/+59 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -1/+1 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1 | -0/+9 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-27 | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1 | -114/+3 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1 | -30/+34 | |
1998-03-27 | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1 | -70/+70 | |
1998-03-27 | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1 | -15/+17 | |
and all directives start with rtems_. | |||||
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-08-04 | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1 | -1/+3 | |
1997-07-31 | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1 | -5/+50 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -16/+17 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -0/+106 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+714 | |
