* bsp_howto/ata.t, bsp_howto/clock.t, bsp_howto/ide-ctrl.t,
bsp_howto/nvmem.t, bsp_howto/shmsupp.t, user/datatypes.t, user/mp.t,
user/userext.t: Eliminate all references to rtems_signedXX and
rtems_unsignedXX.
* user/barrier.t, user/clock.t, user/concepts.t, user/conf.t,
user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t,
user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t,
user/task.t, user/timer.t: Corrected various errors in the
documentation.
* user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t,
user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t,
user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the
Ada documentation to reflect the current binding.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
blows up both makeinfo and texi2dvi. So I have commented them out.
to be correct in either C or Ada.
Added the interrupt disable, enable, flash, and is in progress directives.
changed "97" to "1997"
