path: root/doc/user/mp.t (follow)
* Added "findex" for all directive pages but it turns out that thisJoel Sherrill1998-04-021-0/+1
| | | | blows up both makeinfo and texi2dvi. So I have commented them out.
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-101/+2
* Completed sweep adding directive and constant prefixes.Joel Sherrill1998-03-271-8/+10
* Conditionally adding RTEMS_ and rtems_ prefixes.Joel Sherrill1998-03-271-1/+1
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-1/+1
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* first cut at Ada bindings manualJoel Sherrill1997-05-291-0/+59
* Initial revisionJoel Sherrill1997-05-271-0/+628
