* | 2008-02-14 Joel Sherrill <joel.sherrill@OARcorp.com>4.7.2 | Joel Sherrill | 2008-02-14 | 1 | -5/+0 |
| | | | | * user/mp.t: Now builds. | ||||
* | 2007-11-28 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-11-28 | 1 | -59/+18 |
| | | | | | | | * user/clock.t, user/concepts.t, user/conf.t, user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Corrected various errors in the documentation. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -3/+6 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 1 | -4/+29 |
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+1 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -101/+2 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -8/+10 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -1/+1 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -0/+59 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+628 |
