* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2008-11-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-11-20 | 1 | -12/+55 |
| | | | | | PR 1339/Ada * user/io.t: Re-add IO Manager to Ada binding. | ||||
* | 2008-06-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-06-20 | 1 | -1/+2 |
| | | | | | * user/io.t: Fix typos for IO unregister reported by Catalin Morosan <catalin.morosan at gmail.com>. | ||||
* | 2007-10-25 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-10-25 | 1 | -55/+12 |
| | | | | | | | * user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t, user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t, user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the Ada documentation to reflect the current binding. | ||||
* | 2007-06-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-12 | 1 | -1/+1 |
| | | | | * user/io.t: Fix typo. | ||||
* | 2007-05-29 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-29 | 1 | -0/+3 |
| | | | | * user/io.t: Added error cases to rtems_io_register_driver. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 1 | -1/+1 |
| | | | | * user/io.t: Change rtems_io_register_name to take a const char *. | ||||
* | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-03 | 1 | -2/+2 |
| | | | | | | PR 338/filesystem * io.t: Fix Ada binding as side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | ||||
* | 2003-02-03 Steven Johnson <sjohnson@neurizon.net> | Joel Sherrill | 2003-02-03 | 1 | -1/+1 |
| | | | | | | PR 338/filesystem * io.t: Document the API change that fixed reentrancy problem with rtems_io_lookup_name(). | ||||
* | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-27 | 1 | -6/+0 |
| | | | | * io.t: Correct Ada bindings. | ||||
* | 2002-04-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-03 | 1 | -1/+1 |
| | | | | * io.t: Fix typo @sybsection. | ||||
* | 2002-03-22 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-03-27 | 1 | -5/+128 |
| | | | | | * io.t, conf.t: PR 160. Added the IO Manager's register and unregister interface documentation. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -0/+7 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 1 | -8/+61 |
* | Fixed reference to initialize_executive to use the current name. | Joel Sherrill | 1999-07-01 | 1 | -1/+2 |
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+8 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -104/+3 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -6/+13 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -25/+25 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -1/+2 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -2/+120 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+528 |
