2002-03-28 | 2002-03-27 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 1 | -6/+1 | |
* intr.t: Per PR165, now correctly states that passing a NULL pointer for the return argument is an error. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -1/+8 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 1 | -6/+37 | |
1999-10-06 | Corrected a typo. | Joel Sherrill | 1 | -1/+1 | |
1999-10-01 | Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' | Joel Sherrill | 1 | -3/+3 | |
<ccj@acm.org> suggestion. | |||||
1999-10-01 | Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1 | -0/+10 | |
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1 | -0/+5 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-27 | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1 | -78/+3 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1 | -8/+12 | |
1998-03-27 | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1 | -13/+13 | |
1998-03-27 | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1 | -5/+5 | |
and all directives start with rtems_. | |||||
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1998-01-23 | minor updates .. mostly version | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1 | -2/+6 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -4/+168 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-30 | fixed typos | Joel Sherrill | 1 | -2/+2 | |
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -4/+26 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+300 | |
