2017-01-11 | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 1 | -83/+0 | |
closes #2812. | |||||
2015-12-08 | Add RTEMS linker sets | Sebastian Huber | 1 | -1/+1 | |
Update #2408. | |||||
2014-03-11 | doc: Improve description of rtems_status_text for ToC | Joel Sherrill | 1 | -2/+2 | |
2014-02-12 | score: Change debug helper functions | Sebastian Huber | 1 | -1/+1 | |
Rename rtems_internal_error_description() to rtems_internal_error_text(). Rename rtems_fatal_source_description() to rtems_fatal_source_text(). Rename rtems_status_code_description() to rtems_status_text(). Remove previous implementation of rtems_status_text(). | |||||
2014-02-06 | rtems: Add rtems_status_code_description() | Sebastian Huber | 1 | -1/+1 | |
2013-02-26 | doc/c_user: Fix Lines that were too long | Joel Sherrill | 1 | -7/+7 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-12-06 | 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -3/+1 | |
PR 1793/doc * .cvsignore, Makefile.am, README, configure.ac, index.html.in, main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi, ada_user/example.texi, bsp_howto/.cvsignore, bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore, cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi, develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi, filesystem/.cvsignore, filesystem/filesystem.texi, filesystem/preface.texi, networking/.cvsignore, networking/networking.texi, networking/preface.texi, porting/.cvsignore, porting/porting.texi, porting/preface.texi, posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi, posix_users/.cvsignore, posix_users/posix_users.texi, posix_users/preface.texi, shell/.cvsignore, shell/preface.texi, shell/shell.texi, started/.cvsignore, started/started.texi, user/.cvsignore, user/c_user.texi, user/dirstat.texi, user/example.texi, user/glossary.texi, user/preface.texi: Convert from texi2www to texi2html. * texi2html_init.in: New file. * rtems_footer.html.in, rtems_header.html.in: Removed. | |||||
2007-04-05 | 2007-04-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* user/example.texi: Change all obsoleted CONFIGURE_TEST_NEEDS_XXX configuration constants to CONFIGURE_APPLICATION_NEEDS_XXX. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-05-28 | Updated to reflect lower confdefs.h values and new control | Joel Sherrill | 1 | -0/+2 | |
over number of termios ports. | |||||
2000-05-10 | Added "@" in front of "{" and "}" to make texinfo happy. | Joel Sherrill | 1 | -4/+4 | |
2000-05-10 | Made examples include checking of return status. | Joel Sherrill | 1 | -8/+24 | |
2000-05-05 | Updated example. | Joel Sherrill | 1 | -56/+18 | |
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -3/+6 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1 | -1/+1 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+103 | |
