* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Updated to reflect lower confdefs.h values and new control | Joel Sherrill | 2000-05-28 | 1 | -0/+2 |
| | | | | over number of termios ports. | ||||
* | Added "@" in front of "{" and "}" to make texinfo happy. | Joel Sherrill | 2000-05-10 | 1 | -4/+4 |
* | Made examples include checking of return status. | Joel Sherrill | 2000-05-10 | 1 | -8/+24 |
* | Updated example. | Joel Sherrill | 2000-05-05 | 1 | -56/+18 |
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -3/+6 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+103 |
