path: root/doc/user/event.t (follow)
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-2/+7
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Turned on concept and function name indexing.Joel Sherrill1999-10-111-2/+19
* Added text to clarify the queueing of multiple events.Joel Sherrill1998-08-131-12/+12
* Added "findex" for all directive pages but it turns out that thisJoel Sherrill1998-04-021-1/+3
| | | | blows up both makeinfo and texi2dvi. So I have commented them out.
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-74/+3
* Completed sweep adding directive and constant prefixes.Joel Sherrill1998-03-271-14/+18
* Conditionally adding RTEMS_ and rtems_ prefixes.Joel Sherrill1998-03-271-32/+32
* Attempting to add variable so that in C all constants start with RTEMS_Joel Sherrill1998-03-271-3/+5
| | | | and all directives start with rtems_.
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* Added information based on comments from Katsu Shibuya.Joel Sherrill1997-08-041-0/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-27/+30
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* first cut at Ada bindings manualJoel Sherrill1997-05-291-0/+26
* Initial revisionJoel Sherrill1997-05-271-0/+351
