* | 2008-07-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-15 | 1 | -1/+1 |
| | | | | | | | * user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Correct documentation typos noticed and thankfully reported by FabrÃcio de Novaes Kucinskis <fabricio@dea.inpe.br> | ||||
* | 2007-11-28 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-11-28 | 1 | -5/+5 |
| | | | | | | | | * user/barrier.t, user/clock.t, user/concepts.t, user/conf.t, user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Corrected various errors in the documentation. | ||||
* | 2004-05-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-05-06 | 1 | -2/+6 |
| | | | | | | | PR 618/rtems * user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t, user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL checks. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 1 | -5/+38 |
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+5 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -69/+2 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -6/+9 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -15/+15 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -4/+64 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+324 |
