path: root/doc/user/conf.t (follow)
* Added a lot of information on confdefs.tJoel Sherrill1999-07-031-16/+367
* Unlimited objects information from Chris Johns (ccj@acm.org).Joel Sherrill1999-04-191-12/+36
* Added maximum_timers field to configuration table.Joel Sherrill1999-02-091-1/+1
* Added POSIX timers.Joel Sherrill1999-02-031-0/+6
* Corrected information about the post_switch extension.Joel Sherrill1998-12-171-7/+0
* Per suggestion from Eric Norum, went from one initial extension setJoel Sherrill1998-04-151-12/+19
| | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence.
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-52/+1
* Completed sweep adding directive and constant prefixes.Joel Sherrill1998-03-271-14/+20
* Added Hitachi SHJoel Sherrill1998-03-271-2/+2
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Fixed formatting problem where @example did not start early enough.Joel Sherrill1997-06-041-2/+2
* final corrections before 4.1.0 documentation freeze.Joel Sherrill1997-06-041-5/+5
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-8/+8
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* fixed typosJoel Sherrill1997-05-301-4/+4
* updated to reflect AdaJoel Sherrill1997-05-301-12/+259
* first cut at Ada bindings manualJoel Sherrill1997-05-291-6/+9
* Initial revisionJoel Sherrill1997-05-271-0/+752
