2002-03-27 | 2002-03-22 Chris Johns <ccj@acm.org> | Joel Sherrill | 1 | -8/+23 | |
* io.t, conf.t: PR 160. Added the IO Manager's register and unregister interface documentation. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-05-28 | Updated to reflect lower confdefs.h values and new control | Joel Sherrill | 1 | -11/+71 | |
over number of termios ports. | |||||
2000-05-10 | Removed duplicate NEEDS_CONSOLE_DRIVER. | Joel Sherrill | 1 | -1/+0 | |
2000-05-05 | Added function indexes for CONFIGURE_ constants. | Joel Sherrill | 1 | -1/+85 | |
2000-05-05 | More updates. | Joel Sherrill | 1 | -3/+3 | |
2000-05-05 | Added much information on confdefs.h parameters. | Joel Sherrill | 1 | -78/+437 | |
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -8/+17 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Added categorized list of constants in confdefs.h. | Joel Sherrill | 1 | -0/+126 | |
1999-10-25 | Fixed line too long problems. | Joel Sherrill | 1 | -11/+18 | |
1999-10-25 | Formatting improvements. | Joel Sherrill | 1 | -11/+18 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 1 | -0/+22 | |
1999-07-03 | Added a lot of information on confdefs.t | Joel Sherrill | 1 | -16/+367 | |
1999-04-19 | Unlimited objects information from Chris Johns (ccj@acm.org). | Joel Sherrill | 1 | -12/+36 | |
1999-02-09 | Added maximum_timers field to configuration table. | Joel Sherrill | 1 | -1/+1 | |
1999-02-03 | Added POSIX timers. | Joel Sherrill | 1 | -0/+6 | |
1998-12-17 | Corrected information about the post_switch extension. | Joel Sherrill | 1 | -7/+0 | |
1998-04-15 | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1 | -12/+19 | |
to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
1998-03-27 | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1 | -52/+1 | |
1998-03-27 | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1 | -14/+20 | |
1998-03-27 | Added Hitachi SH | Joel Sherrill | 1 | -2/+2 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1 | -2/+2 | |
1997-06-04 | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1 | -5/+5 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -8/+8 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-30 | fixed typos | Joel Sherrill | 1 | -4/+4 | |
1997-05-30 | updated to reflect Ada | Joel Sherrill | 1 | -12/+259 | |
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -6/+9 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+752 | |
