PR 1851/doc
* user/conf.t: Fix typo in CONFIGURE_MESSAGE_BUFFER_MEMORY example.
* user/conf.t: Fix typos.
* user/conf.t: Add SMP Configuration parameters.
* user/conf.t: Slight rework to deemphasize not using confdefs.h
PR 1743/cpu
* user/conf.t: Add Simple Priority Scheduler as complement to existing
Deterministic Priority Scheduler. This scheduler serves both as an
example and as a lighter weight implementation for smaller systems.
* user/conf.t: Document changes to Scheduler configuration.
PR 1647/cpukit
* user/conf.t, user/schedule.t: Update documentation to reflect
refactoring of SuperCore to add Scheduler and ability for user to
configure a scheduler.
* Makefile.am, configure.ac, index.html.in, develenv/direct.t,
posix_users/gen_size_report, started/nextstep.t,
started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API.
* itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t,
itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all,
itron3.0/gen_section, itron3.0/gen_status_shell,
itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t,
itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t,
itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t,
itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t,
itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
* user/conf.t: CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
* user/conf.t, user/userext.t: Eliminate use of deprecated
rtems_extension.
* user/conf.t: Change stack allocator signature.
* user/conf.t: Add configuration of posix message queue file
descriptors as separate entity. Also add documentation on posix
configuration elements not previously covered.
* bsp_howto/.cvsignore, bsp_howto/Makefile.am,
bsp_howto/bsp_howto.texi: Add Frame Buffer Device Driver shell.
* bsp_howto/framebuffer.t: New file.
* user/conf.t: Add CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER.
* user/conf.t: Change work_space_size to uintptr_t since it cannot be
negative.
* user/conf.t, user/region.t: Change sizes of heap/region and allocated
objects in heap to intptr_t so they can be larger than a single
allocatable object (e.g. size_t).
* user/conf.t: Fix typo.
* user/conf.t: Add CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM and
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* shell/rtems.t, user/conf.t, user/stackchk.t: Rename STACK_CHECKER_ON
to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* user/conf.t: Add support for optionally having a unified work area.
In other words, the RTEMS Workspace and C Program Heap are the same
pool of memory.
* user/conf.t: Add CONFIGURE_BSP_PREREQUISITE_DRIVERS and
CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS.
* user/conf.t: Add CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS.
* user/conf.t: Add CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION and
CONFIGURE_MAXIMUM_PRIORITY.
* user/conf.t: Add CONFIGURE_MINIMUM_STACK_SIZE.
* user/bsp.t, user/conf.t, user/task.t: Add ability for application to
configure minimum stack size. Add RTEMS_CONFIGURED_MINIMUM_STACK_SIZE
constant so user can clearly indicate they want the configured as
opposed to the recommended minimum stack size.
* started/buildc.t: Add paragraph on see CVS for latest patches.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE and example
of how to compute message CONFIGURE_MESSAGE_BUFFER_MEMORY using it.
* user/conf.t: Add baseline interface for Watchdog Driver.
* user/conf.t: Fix text on CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER.
* user/conf.t: Fix typo on
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* user/conf.t: Add CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* user/bsp.t, user/conf.t, user/init.t, user/intr.t, user/overview.t,
user/timer.t: Correct default values. Make it clear that confdefs.h
calculates the memory required for you.
* user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t,
user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t,
user/userext.t: Add new Object Services collection. Tidy up some
configuration documentation from earlier changes.
* user/object.t: New file.
* cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, porting/cpuinit.t,
user/conf.t, user/init.t: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, user/conf.t: Moved
most of the remaining CPU Table fields to the Configuration Table.
This included pretasking_hook, predriver_hook, postdriver_hook,
idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* user/barrier.t, user/clock.t, user/concepts.t, user/conf.t,
user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t,
user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t,
user/task.t, user/timer.t: Corrected various errors in the
documentation.
* user/conf.t: Add CONFIGURE_APPLICATION_EXTRA_DRIVERS.
* user/conf.t: Eliminate maximum_drivers configuration parameter since
it was used to configure a no longer used feature. Device names are
now part of the filesystem not in a table. This also eliminated the
variables _IO_Number_of_devices and _IO_Driver_name_table from RTEMS
as well as the memory allocation used to populate
_IO_Driver_name_table.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFER_MEMORY. Use
rtems/confdefs.h instead of old confdefs.h.
* user/conf.t: Fix typo -- should have read kilobytes.
PR 1226/cpukit
* user/conf.t: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE not
CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
over number of termios ports.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
