1998-03-27 | Added Hitachi SH | Joel Sherrill | 1 | -27/+27 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-07-31 | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1 | -0/+36 | |
for the pointer to a "return area".. | |||||
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1 | -4/+4 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -11/+19 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -1/+62 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+356 | |
