path: root/doc/user/c_user.texi (follow)
* Added Data Types Chapter.Joel Sherrill2000-05-081-0/+2
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Corrected spacing.Joel Sherrill1999-10-111-1/+0
* Turned on concept and function name indexing.Joel Sherrill1999-10-111-4/+6
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-011-1/+1
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Went back to not printing an index. makeinfo does fine if you have indicesJoel Sherrill1998-04-021-1/+3
| | | | but do not print them. texi2dvi barfs if the entries are even there.
* Added "findex" for all directive pages but it turns out that thisJoel Sherrill1998-04-021-3/+1
| | | | blows up both makeinfo and texi2dvi. So I have commented them out.
* Added Hitachi SHJoel Sherrill1998-03-271-0/+1
* Attempting to add variable so that in C all constants start with RTEMS_Joel Sherrill1998-03-271-0/+1
| | | | and all directives start with rtems_.
* Added variables for dates and revision infoJoel Sherrill1998-03-261-4/+4
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* minor updates .. mostly versionJoel Sherrill1998-01-231-4/+5
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* changed edition and version informationJoel Sherrill1997-06-041-2/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-7/+8
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* first cut at Ada bindings manualJoel Sherrill1997-05-291-1/+5
* version changedJoel Sherrill1997-05-281-2/+2
* 4.0.0 release docsJoel Sherrill1997-05-281-2/+2
* Initial revisionJoel Sherrill1997-05-271-0/+159
