1999-10-11 | Corrected spacing. | Joel Sherrill | 1 | -1/+0 | |
1999-10-11 | Turned on concept and function name indexing. | Joel Sherrill | 1 | -4/+6 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -1/+1 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1998-04-02 | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1 | -1/+3 | |
but do not print them. texi2dvi barfs if the entries are even there. | |||||
1998-04-02 | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1 | -3/+1 | |
blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
1998-03-27 | Added Hitachi SH | Joel Sherrill | 1 | -0/+1 | |
1998-03-27 | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1 | -0/+1 | |
and all directives start with rtems_. | |||||
1998-03-26 | Added variables for dates and revision info | Joel Sherrill | 1 | -4/+4 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1998-01-23 | minor updates .. mostly version | Joel Sherrill | 1 | -4/+5 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-06-04 | changed edition and version information | Joel Sherrill | 1 | -2/+2 | |
1997-05-31 | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1 | -7/+8 | |
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | |||||
1997-05-29 | first cut at Ada bindings manual | Joel Sherrill | 1 | -1/+5 | |
1997-05-28 | version changed | Joel Sherrill | 1 | -2/+2 | |
1997-05-28 | 4.0.0 release docs | Joel Sherrill | 1 | -2/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+159 | |
