* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -7/+8 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -1/+5 |
* | version changed | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+159 |
