* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -1/+1 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 1 | -1/+3 |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | ||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -3/+1 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Added Hitachi SH | Joel Sherrill | 1998-03-27 | 1 | -0/+1 |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 1 | -0/+1 |
| | | | | and all directives start with rtems_. | ||||
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 1 | -4/+5 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -7/+8 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -1/+5 |
* | version changed | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+159 |
