* | doc/user Object Id Figures: Correct rotation and border | Joel Sherrill | 2013-02-26 | 1 | -23064/+3791 |
| | | | | | | | | | The 16 bit Object Id image was incorrectly rotated in the manual. Both the 16 and 32 Object Id bit images had thin borders on the table and the bottom line was not visible in the PDF. I tinkered with the original drawings to add a bit more space around the tables and manually converted the PNG to EPS using Gimp to ensure a controlled and high quality conversion. | ||||
* | 2008-12-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-01 | 1 | -0/+23070 |
* ada_user/Makefile.am, user/Makefile.am, user/concepts.t: Add 16 bit object Id format information. * user/ObjectId-16Bits.eps, user/ObjectId-16Bits.png: New files. |
