2004-02-05 | 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -143/+0 | |
* ChangeLog: Merge-in user/ChangeLog. * user/ChangeLog: Remove. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Cosmetics. | |||||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
2003-11-26 | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos. | |||||
2003-11-25 | 2003-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 528/rtems_misc * task.t: Fix Ada binding for task variable calls. | |||||
2003-11-21 | 2003-11-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 521/doc * sem.t: Default attributes were wrong for semaphores. | |||||
2003-09-29 | 2003-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* preface.texi: Eliminate references to HPPA. | |||||
2003-09-22 | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Merger from rtems-4-6-branch. | |||||
2003-09-19 | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch. | |||||
2003-05-22 | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
* fatal.t: Reflect c/src/exec having moved to cpukit. | |||||
2003-02-14 | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* preface.texi: Remove a29k references and update. | |||||
2003-02-03 | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
PR 338/filesystem * io.t: Fix Ada binding as side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | |||||
2003-02-03 | 2003-02-03 Steven Johnson <sjohnson@neurizon.net> | Joel Sherrill | 1 | -0/+6 | |
PR 338/filesystem * io.t: Document the API change that fixed reentrancy problem with rtems_io_lookup_name(). | |||||
2003-01-25 | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* c_user.texi: Set @setfilename c_user.info. | |||||
2003-01-24 | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Put GENERATED_FILES into $builddir. | |||||
2003-01-22 | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+8 | |
* version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | |||||
2003-01-21 | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* stamp-vti, version.texi: Regenerated. | |||||
2002-11-13 | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
2002-10-24 | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
2002-08-27 | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* io.t: Correct Ada bindings. | |||||
2002-07-31 | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
2002-06-28 | 2002-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* userext.t: Per PR228, correct the prototype of the task create user extension to indicate it returns a boolean and augment the documentation to explain the purpose of the boolean return value. | |||||
2002-04-13 | 2002-04-12 Chris Johns <ccj@acm.org> | Joel Sherrill | 1 | -0/+6 | |
* doc/user/userext.t: Per PR138, updated the documentation to show how to obtain an extension table index. Also provided some extra background on the user extension API. | |||||
2002-04-03 | 2002-04-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* io.t: Fix typo @sybsection. | |||||
2002-03-28 | 2002-03-27 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 1 | -0/+5 | |
* intr.t: Per PR165, now correctly states that passing a NULL pointer for the return argument is an error. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2002-03-27 | 2002-03-27 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 1 | -0/+5 | |
* PR161 * rtmon.t: Add rtems_ prefix to directives in the example. | |||||
2002-03-27 | 2002-03-22 Chris Johns <ccj@acm.org> | Joel Sherrill | 1 | -0/+5 | |
* io.t, conf.t: PR 160. Added the IO Manager's register and unregister interface documentation. | |||||
2002-03-15 | 2002-03-15 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 1 | -0/+4 | |
* rtmon.t: Correct example and correctly used ensure not insure. | |||||
2002-01-18 | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: include main.am, require automake-1.5. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* .cvsignore: Added rtems_header.html and rtems_footer.html. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* timer.t: Added task-based timer information including the new directives rtems_timer_initiate(), rtems_timer_server_fire_after(), and rtems_timer_server_fire_when(). | |||||
2000-08-25 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+0 | |
2000-08-10 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+3 | |
