* io.t: Correct Ada bindings.
* userext.t: Per PR228, correct the prototype of the task create
user extension to indicate it returns a boolean and augment the
documentation to explain the purpose of the boolean return value.
* doc/user/userext.t: Per PR138, updated the documentation to show
how to obtain an extension table index. Also provided some extra
background on the user extension API.
* io.t: Fix typo @sybsection.
* intr.t: Per PR165, now correctly states that passing a NULL
pointer for the return argument is an error.
* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* rtmon.t: Correct example and correctly used ensure not insure.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
