* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 1 | -0/+4 |
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -0/+5 |
| | | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos. | ||||
* | 2003-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-11-25 | 1 | -0/+5 |
| | | | | | PR 528/rtems_misc * task.t: Fix Ada binding for task variable calls. | ||||
* | 2003-11-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-11-21 | 1 | -0/+5 |
| | | | | | PR 521/doc * sem.t: Default attributes were wrong for semaphores. | ||||
* | 2003-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-29 | 1 | -0/+4 |
| | | | | * preface.texi: Eliminate references to HPPA. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 1 | -0/+4 |
| | | | | * Makefile.am: Merger from rtems-4-6-branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -0/+4 |
| | | | | * c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch. | ||||
* | 2003-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-22 | 1 | -2/+2 |
| | | | | * fatal.t: Reflect c/src/exec having moved to cpukit. | ||||
* | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-14 | 1 | -0/+4 |
| | | | | * preface.texi: Remove a29k references and update. | ||||
* | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-03 | 1 | -0/+6 |
| | | | | | | PR 338/filesystem * io.t: Fix Ada binding as side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | ||||
* | 2003-02-03 Steven Johnson <sjohnson@neurizon.net> | Joel Sherrill | 2003-02-03 | 1 | -0/+6 |
| | | | | | | PR 338/filesystem * io.t: Document the API change that fixed reentrancy problem with rtems_io_lookup_name(). | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 1 | -0/+4 |
| | | | | * c_user.texi: Set @setfilename c_user.info. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 1 | -0/+4 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 1 | -0/+8 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 1 | -0/+4 |
| | | | | * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+4 |
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 1 | -0/+4 |
* | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-27 | 1 | -0/+4 |
| | | | | * io.t: Correct Ada bindings. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 1 | -0/+4 |
* | 2002-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -0/+6 |
| | | | | | | * userext.t: Per PR228, correct the prototype of the task create user extension to indicate it returns a boolean and augment the documentation to explain the purpose of the boolean return value. | ||||
* | 2002-04-12 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-04-13 | 1 | -0/+6 |
| | | | | | | * doc/user/userext.t: Per PR138, updated the documentation to show how to obtain an extension table index. Also provided some extra background on the user extension API. | ||||
* | 2002-04-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-03 | 1 | -0/+4 |
| | | | | * io.t: Fix typo @sybsection. | ||||
* | 2002-03-27 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2002-03-28 | 1 | -0/+5 |
| | | | | | * intr.t: Per PR165, now correctly states that passing a NULL pointer for the return argument is an error. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-03-27 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2002-03-27 | 1 | -0/+5 |
| | | | | | * PR161 * rtmon.t: Add rtems_ prefix to directives in the example. | ||||
* | 2002-03-22 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-03-27 | 1 | -0/+5 |
| | | | | | * io.t, conf.t: PR 160. Added the IO Manager's register and unregister interface documentation. | ||||
* | 2002-03-15 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2002-03-15 | 1 | -0/+4 |
| | | | | * rtmon.t: Correct example and correctly used ensure not insure. | ||||
* | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-18 | 1 | -0/+4 |
| | | | | * Makefile.am: include main.am, require automake-1.5. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -0/+4 |
| | | | | * .cvsignore: Added rtems_header.html and rtems_footer.html. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -0/+6 |
| | | | | | | * timer.t: Added task-based timer information including the new directives rtems_timer_initiate(), rtems_timer_server_fire_after(), and rtems_timer_server_fire_when(). | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-25 | 1 | -0/+3 |
