path: root/doc/tools (unfollow)
2000-08-25Adding ChangeLogs.Joel Sherrill6-0/+18
2000-06-10Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill9-58/+32
which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
2000-06-01Removed old bmenu version.Joel Sherrill2-1067/+1
2000-05-31Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-3/+17
Adds a -I <path> option to texi2www. This option is supposed to compatible to the option of the same name in makeinfo, texi2dvi etc. [This patch actually is kind of a hack, but it works :]
2000-05-08Patch from Ralf Corsepies <corsepiu@faw.uni-ulm.de> thatJoel Sherrill3-223/+2
fixes handling of word-replace and removes tool/update.
2000-05-01Removed file rendered obsolete by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill2-90/+1
2000-05-01New file added by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill1-0/+1045
2000-05-01Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill11-25/+39
It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
2000-04-27New files. First attempt.Joel Sherrill9-0/+28
2000-04-26Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document.
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill16-233/+314
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
1999-11-16Changed copyright date to 1999.Joel Sherrill12-12/+12
1999-10-11Added support for @appendix and @preface.Joel Sherrill1-0/+12
1999-10-11Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill2-5/+7
1999-10-07Enhanced to support @email{} as supported in texi2html in texinfo 4.0.Joel Sherrill1-0/+5
This way we maintain compatibility but continue to use the better, more flexible tool.
1999-10-07Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill2-2/+2
pdf version of figures.
1999-10-01Numerous minor changes required to transition to the latest versionJoel Sherrill6-13/+27
of texinfo and TeX. This version of the tools can produce PDF with figures included.
1999-07-03Removed concept of distribution level.Joel Sherrill1-1/+0
1999-04-06Sanitized.Joel Sherrill1-3/+0
1999-04-06Removed.Joel Sherrill6-2860/+0
1998-10-27Minor change to ease debugging.Joel Sherrill1-1/+3
1998-10-20New picture.Joel Sherrill1-0/+0
1998-05-12Added test case for table -- barfs when optimization is enabledJoel Sherrill1-0/+27
1998-04-14RTEMS stuff now browseable for 1st time. Not completed.Joel Sherrill2-3/+8
1998-04-14Added emacs Ada tags stuffJoel Sherrill3-0/+444
1998-04-14building up src2htmlJoel Sherrill1-0/+37
1998-04-14base changes for moving and better error checkingJoel Sherrill1-2/+21
1998-04-14New file. Copied from Avenger.Joel Sherrill1-0/+18
1998-04-14Added Ada support by copying the script from Avenger.Joel Sherrill1-40/+155
1998-04-14switched to gccJoel Sherrill1-2/+5
1998-04-14New filesJoel Sherrill32-0/+2942
1998-04-13Changed from Top to index as top nodeJoel Sherrill1-1/+1
1998-04-03Moved the terminate node since the "cprev" was being overwritten.Joel Sherrill1-2/+2
1998-04-03Moved from common directory since they belong to the texi2www distribution.Joel Sherrill5-0/+0
1998-04-03Removed incorrect comment.Joel Sherrill1-1/+0
1998-04-03Renamed.Joel Sherrill1-1/+1
1998-04-03Nowbiulds html and ps. Info not supported.Joel Sherrill1-3/+4
1998-04-03Added shortname generation support with the capability for the userJoel Sherrill1-5/+37
to specify the base of the name. BASEnnnn.html
1998-04-03Added fourth icon which takes user back to the indexJoel Sherrill1-26/+43
1998-04-03Added -header and -dirfile options.Joel Sherrill1-2/+23
1998-04-03Base fileJoel Sherrill4-1/+53
1998-04-03Changed Perl executable locationJoel Sherrill2-2/+2
1998-04-03Base files from texi2www-960103Joel Sherrill4-0/+2122
1998-03-27Localized for use in doc tree.Joel Sherrill1-2/+7
1998-03-26removed @ifinfo around something needed for html structureJoel Sherrill1-2/+2
1998-02-11new test casesJoel Sherrill2-0/+92
1998-02-06Updated copyrightsJoel Sherrill10-10/+10
1998-02-06Added @table/@end table capability along with the avdas.d test case whereJoel Sherrill3-3/+363
this capability was first used.
1998-02-05Added code to more correctly process abstract types (handle, range, etc).Joel Sherrill2-22/+76
1998-01-30Modified output of @Example style in MsWord output routine so it wouldJoel Sherrill2-4/+36
be one paragraph with manual line breaks rather than multiple paragraphs..
