path: root/doc/tools (follow)
* Added support for @appendix and @preface.Joel Sherrill1999-10-111-0/+12
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-112-5/+7
* Enhanced to support @email{} as supported in texi2html in texinfo 4.0.Joel Sherrill1999-10-071-0/+5
| | | | | This way we maintain compatibility but continue to use the better, more flexible tool.
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-072-2/+2
| | | | pdf version of figures.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-016-13/+27
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Sanitized.Joel Sherrill1999-04-061-3/+0
* Removed.Joel Sherrill1999-04-066-2860/+0
* Minor change to ease debugging.Joel Sherrill1998-10-271-1/+3
* New picture.Joel Sherrill1998-10-201-0/+0
* Added test case for table -- barfs when optimization is enabledJoel Sherrill1998-05-121-0/+27
* RTEMS stuff now browseable for 1st time. Not completed.Joel Sherrill1998-04-142-3/+8
* Added emacs Ada tags stuffJoel Sherrill1998-04-143-0/+444
* building up src2htmlJoel Sherrill1998-04-141-0/+37
* base changes for moving and better error checkingJoel Sherrill1998-04-141-2/+21
* New file. Copied from Avenger.Joel Sherrill1998-04-141-0/+18
* Added Ada support by copying the script from Avenger.Joel Sherrill1998-04-141-40/+155
* switched to gccJoel Sherrill1998-04-141-2/+5
* New filesJoel Sherrill1998-04-1432-0/+2942
* Changed from Top to index as top nodeJoel Sherrill1998-04-131-1/+1
* Moved the terminate node since the "cprev" was being overwritten.Joel Sherrill1998-04-031-2/+2
* Moved from common directory since they belong to the texi2www distribution.Joel Sherrill1998-04-035-0/+0
* Removed incorrect comment.Joel Sherrill1998-04-031-1/+0
* Renamed.Joel Sherrill1998-04-031-1/+1
* Nowbiulds html and ps. Info not supported.Joel Sherrill1998-04-031-3/+4
* Added shortname generation support with the capability for the userJoel Sherrill1998-04-031-5/+37
| | | | to specify the base of the name. BASEnnnn.html
* Added fourth icon which takes user back to the indexJoel Sherrill1998-04-031-26/+43
* Added -header and -dirfile options.Joel Sherrill1998-04-031-2/+23
* Base fileJoel Sherrill1998-04-034-1/+53
* Changed Perl executable locationJoel Sherrill1998-04-032-2/+2
* Base files from texi2www-960103Joel Sherrill1998-04-034-0/+2122
* Localized for use in doc tree.Joel Sherrill1998-03-271-2/+7
* removed @ifinfo around something needed for html structureJoel Sherrill1998-03-261-2/+2
* new test casesJoel Sherrill1998-02-112-0/+92
* Updated copyrightsJoel Sherrill1998-02-0610-10/+10
* Added @table/@end table capability along with the avdas.d test case whereJoel Sherrill1998-02-063-3/+363
| | | | this capability was first used.
* Added code to more correctly process abstract types (handle, range, etc).Joel Sherrill1998-02-052-22/+76
* Modified output of @Example style in MsWord output routine so it wouldJoel Sherrill1998-01-302-4/+36
| | | | be one paragraph with manual line breaks rather than multiple paragraphs..
* Fixed some "NodeNameIncludesChapterName" problems which were uncoveredJoel Sherrill1998-01-231-11/+29
| | | | doing the HWAPI manual.
* Added Code to dop the output in a format which a custom Visual BasicJoel Sherrill1998-01-213-10/+203
| | | | Application Cindy has written can transform into a nice Word document.
* Test document.Joel Sherrill1997-10-311-0/+690
* New test file.Joel Sherrill1997-10-311-4/+4
* Replaced the algorithm used to build the texinfo nodes and menus. ThisJoel Sherrill1997-10-311-218/+236
| | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names.
* Added command line options for next, previous, and up node.Joel Sherrill1997-08-151-7/+28
| | | | | Added error check to insure we don't write over a .texi file given to us as input.
* removed binary filesJoel Sherrill1997-08-043-0/+0
* This commit was generated by cvs2svn to compensate for changes in r930,Joel Sherrill1997-06-169-0/+1379
|\ | | | | which included commits to RCS files with non-trunk default branches.
| * base PDL 2 TEXIJoel Sherrill1997-06-169-0/+1379
* Initial revisionJoel Sherrill1997-06-167-0/+5348
* added CVS Id stringJoel Sherrill1997-06-0412-28/+51
* Initial revisionJoel Sherrill1997-05-2715-0/+2547
