* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 12 | -12/+12 | |
* | Added support for @appendix and @preface. | Joel Sherrill | 1999-10-11 | 1 | -0/+12 | |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 2 | -5/+7 | |
* | Enhanced to support @email{} as supported in texi2html in texinfo 4.0. | Joel Sherrill | 1999-10-07 | 1 | -0/+5 | |
| | | | | | This way we maintain compatibility but continue to use the better, more flexible tool. | |||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 2 | -2/+2 | |
| | | | | pdf version of figures. | |||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 6 | -13/+27 | |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 | |
* | Sanitized. | Joel Sherrill | 1999-04-06 | 1 | -3/+0 | |
* | Removed. | Joel Sherrill | 1999-04-06 | 6 | -2860/+0 | |
* | Minor change to ease debugging. | Joel Sherrill | 1998-10-27 | 1 | -1/+3 | |
* | New picture. | Joel Sherrill | 1998-10-20 | 1 | -0/+0 | |
* | Added test case for table -- barfs when optimization is enabled | Joel Sherrill | 1998-05-12 | 1 | -0/+27 | |
* | RTEMS stuff now browseable for 1st time. Not completed. | Joel Sherrill | 1998-04-14 | 2 | -3/+8 | |
* | Added emacs Ada tags stuff | Joel Sherrill | 1998-04-14 | 3 | -0/+444 | |
* | building up src2html | Joel Sherrill | 1998-04-14 | 1 | -0/+37 | |
* | base changes for moving and better error checking | Joel Sherrill | 1998-04-14 | 1 | -2/+21 | |
* | New file. Copied from Avenger. | Joel Sherrill | 1998-04-14 | 1 | -0/+18 | |
* | Added Ada support by copying the script from Avenger. | Joel Sherrill | 1998-04-14 | 1 | -40/+155 | |
* | switched to gcc | Joel Sherrill | 1998-04-14 | 1 | -2/+5 | |
* | New files | Joel Sherrill | 1998-04-14 | 32 | -0/+2942 | |
* | Changed from Top to index as top node | Joel Sherrill | 1998-04-13 | 1 | -1/+1 | |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 | |
* | Moved from common directory since they belong to the texi2www distribution. | Joel Sherrill | 1998-04-03 | 5 | -0/+0 | |
* | Removed incorrect comment. | Joel Sherrill | 1998-04-03 | 1 | -1/+0 | |
* | Renamed. | Joel Sherrill | 1998-04-03 | 1 | -1/+1 | |
* | Nowbiulds html and ps. Info not supported. | Joel Sherrill | 1998-04-03 | 1 | -3/+4 | |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 | |
| | | | | to specify the base of the name. BASEnnnn.html | |||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 | |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 | |
* | Base file | Joel Sherrill | 1998-04-03 | 4 | -1/+53 | |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 2 | -2/+2 | |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 4 | -0/+2122 | |
* | Localized for use in doc tree. | Joel Sherrill | 1998-03-27 | 1 | -2/+7 | |
* | removed @ifinfo around something needed for html structure | Joel Sherrill | 1998-03-26 | 1 | -2/+2 | |
* | new test cases | Joel Sherrill | 1998-02-11 | 2 | -0/+92 | |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 10 | -10/+10 | |
* | Added @table/@end table capability along with the avdas.d test case where | Joel Sherrill | 1998-02-06 | 3 | -3/+363 | |
| | | | | this capability was first used. | |||||
* | Added code to more correctly process abstract types (handle, range, etc). | Joel Sherrill | 1998-02-05 | 2 | -22/+76 | |
* | Modified output of @Example style in MsWord output routine so it would | Joel Sherrill | 1998-01-30 | 2 | -4/+36 | |
| | | | | be one paragraph with manual line breaks rather than multiple paragraphs.. | |||||
* | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1998-01-23 | 1 | -11/+29 | |
| | | | | doing the HWAPI manual. | |||||
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 3 | -10/+203 | |
| | | | | Application Cindy has written can transform into a nice Word document. | |||||
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 | |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 | |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 | |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | |||||
* | Added command line options for next, previous, and up node. | Joel Sherrill | 1997-08-15 | 1 | -7/+28 | |
| | | | | | Added error check to insure we don't write over a .texi file given to us as input. | |||||
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 | |
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | |||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
* | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 | |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 12 | -28/+51 | |
