These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
PR 1793/doc
* Makefile.am, configure.ac, bmenu/bmenu2.c: Convert from texi2www to
texi2html.
* texi2www/ChangeLog, texi2www/Makefile.am, texi2www/dir-arrow.gif,
texi2www/missing-arrow.gif, texi2www/next-arrow.gif,
texi2www/prev-arrow.gif, texi2www/texi2dvi, texi2www/texi2www,
texi2www/texi2www.texi, texi2www/up-arrow.gif: Removed.
* texi2www/texi2www: Add some new texinfo commands.
* base.h: Remove Lines, Verbose, EXTERN.
* menu2.c: Add Lines, Verbose. Remove EXTERN.
* base.h: Remove BlankAsWarnings.
* base.h: Remove NumberOf*.
* address.h, address.inl, chain.c, chain.h, system.h:
Eliminate unsigned8, unsigned16, unsigned32.
Use size_t, ptrdiff_t, intptr_t for 64bit compliance.
* chain.c: Reflect removal of isr.h.
* isr.h: Remove.
* Makefile.am: Remove isr.h.
* texi2www: Add provisory support for @image.
* Makefile.am: Cosmetics.
* system.h: Remove USE_INLINES.
* chain.c: Remove USE_INLINES.
* configure.ac: Merger from rtems-4-6-branch.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* texi2www: Add support for @ifnottex.
PR 347/rtems
* rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline
assembly so it correctly generates on newer gcc's.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* Ctags/Makefile.am: Remove AUTOMAKE_OPTIONS.
* FreeBSD/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ctags-emacs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Autoupdate to 2.52.
Remove pdl2texi.
* Makefile.am: Remove pdl2texi.
* ctags-emacs/Makefile.am: Ditto.
* FreeBSD/Makefile.am: Ditto.
* Ctags/Makefile.am: Ditto.
