1998-05-12 | Added test case for table -- barfs when optimization is enabled | Joel Sherrill | 1 | -0/+27 | |
1998-04-14 | RTEMS stuff now browseable for 1st time. Not completed. | Joel Sherrill | 2 | -3/+8 | |
1998-04-14 | Added emacs Ada tags stuff | Joel Sherrill | 3 | -0/+444 | |
1998-04-14 | building up src2html | Joel Sherrill | 1 | -0/+37 | |
1998-04-14 | base changes for moving and better error checking | Joel Sherrill | 1 | -2/+21 | |
1998-04-14 | New file. Copied from Avenger. | Joel Sherrill | 1 | -0/+18 | |
1998-04-14 | Added Ada support by copying the script from Avenger. | Joel Sherrill | 1 | -40/+155 | |
1998-04-14 | switched to gcc | Joel Sherrill | 1 | -2/+5 | |
1998-04-14 | New files | Joel Sherrill | 32 | -0/+2942 | |
1998-04-13 | Changed from Top to index as top node | Joel Sherrill | 1 | -1/+1 | |
1998-04-03 | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1 | -2/+2 | |
1998-04-03 | Moved from common directory since they belong to the texi2www distribution. | Joel Sherrill | 5 | -0/+0 | |
1998-04-03 | Removed incorrect comment. | Joel Sherrill | 1 | -1/+0 | |
1998-04-03 | Renamed. | Joel Sherrill | 1 | -1/+1 | |
1998-04-03 | Nowbiulds html and ps. Info not supported. | Joel Sherrill | 1 | -3/+4 | |
1998-04-03 | Added shortname generation support with the capability for the user | Joel Sherrill | 1 | -5/+37 | |
to specify the base of the name. BASEnnnn.html | |||||
1998-04-03 | Added fourth icon which takes user back to the index | Joel Sherrill | 1 | -26/+43 | |
1998-04-03 | Added -header and -dirfile options. | Joel Sherrill | 1 | -2/+23 | |
1998-04-03 | Base file | Joel Sherrill | 4 | -1/+53 | |
1998-04-03 | Changed Perl executable location | Joel Sherrill | 2 | -2/+2 | |
1998-04-03 | Base files from texi2www-960103 | Joel Sherrill | 4 | -0/+2122 | |
1998-03-27 | Localized for use in doc tree. | Joel Sherrill | 1 | -2/+7 | |
1998-03-26 | removed @ifinfo around something needed for html structure | Joel Sherrill | 1 | -2/+2 | |
1998-02-11 | new test cases | Joel Sherrill | 2 | -0/+92 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 10 | -10/+10 | |
1998-02-06 | Added @table/@end table capability along with the avdas.d test case where | Joel Sherrill | 3 | -3/+363 | |
this capability was first used. | |||||
1998-02-05 | Added code to more correctly process abstract types (handle, range, etc). | Joel Sherrill | 2 | -22/+76 | |
1998-01-30 | Modified output of @Example style in MsWord output routine so it would | Joel Sherrill | 2 | -4/+36 | |
be one paragraph with manual line breaks rather than multiple paragraphs.. | |||||
1998-01-23 | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1 | -11/+29 | |
doing the HWAPI manual. | |||||
1998-01-21 | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 3 | -10/+203 | |
Application Cindy has written can transform into a nice Word document. | |||||
1997-10-31 | Test document. | Joel Sherrill | 1 | -0/+690 | |
1997-10-31 | New test file. | Joel Sherrill | 1 | -4/+4 | |
1997-10-31 | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1 | -218/+236 | |
was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | |||||
1997-08-15 | Added command line options for next, previous, and up node. | Joel Sherrill | 1 | -7/+28 | |
Added error check to insure we don't write over a .texi file given to us as input. | |||||
1997-08-04 | removed binary files | Joel Sherrill | 3 | -0/+0 | |
1997-06-16 | base PDL 2 TEXI | Joel Sherrill | 9 | -0/+1379 | |
1997-06-16 | Initial revision | Joel Sherrill | 7 | -0/+5348 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 12 | -28/+51 | |
1997-05-27 | Initial revision | Joel Sherrill | 15 | -0/+2547 | |
